Led or halogen T3s for a 1968 Olds 98
Old Nov 12, 2025 | 10:12 PM
AussieIan's Avatar
Is there an aftermarket LED or Halogen low-beam T3 sealed headlamp that fits a 1968 Olds 98 available? If so, would the existing cable harness be adequate to handle the load?
Old Nov 13, 2025 | 04:15 AM
PN's H5001 is for a high beams and H5006 are for low beams if you just want sealed beam replacements. You can use the stock wiring for them.
If you want reproduction T3's then try these, they are available also through assorted repro parts suppliers.
Reproduction T-3 Headlight Bulbs (Sealed Beam ), Small Bulb Kits, & Fuse/Flasher Sets for Classic & Muscle Cars
Old Nov 13, 2025 | 05:12 AM
70sgeek's Avatar
'72 Cutlass ragtop
Here's a great lighting vendor whom you can check out for possible options
https://www.danielsternlighting.com/.../products.html
Old Nov 13, 2025 | 05:45 AM
If you want a correct T3 lens with improved illumination, the only thing I've seen that works is gluing the T3 lenses onto a H4 halogen reflector, as written up in Rod and Custom in 2010.
https://www.hotrod.com/how-to/1006rc...ors-conversion
https://www.jalopyjournal.com/forum/...ights.1209713/
Old Nov 13, 2025 | 06:29 AM
Tri-Carb's Avatar
Here is a picture of the correct 68 T3 lens:
Old Dec 4, 2025 | 12:20 PM
dukeomer's Avatar
I installed these on my 1968 Olds 98.  LED headlamps with DRL's (white) as well as directional indicator (amber).  Got them from Amazon
Old Dec 4, 2025 | 03:32 PM
VC455's Avatar
Barely Registered
Originally Posted by AussieIan
...would the existing cable harness be adequate to handle the load?
Both LED and halogen lights are more efficient than the original T-3s. And, since the light output is limited by regulation, this means that your new lights will take less power than the T-3s.
But, the existing harness has quite a bit of voltage drop, made worse by age and corrosion of connectors. For LEDs, this will matter very little. But if you choose halogens, you may want to install two relays, one for high beams and one for low beams. Switch the relays on and off with the original headlight wiring. Power the relays through a circuit breaker direct from the battery.
By using relays you will get nearly double the light output from T-3s or halogens. Daniel Stern (referenced by 70sgeek in post 3) will have a kit to accomplish this.
Oldsfan
Ninety-Eight
Jul 22, 2024 07:25 PM
AussieIan
Sep 7, 2022 01:08 PM
AussieIan
Aug 6, 2021 04:07 PM
shiftbyear
Jul 19, 2018 03:12 AM
The Tin Man
Aug 5, 2011 05:40 AM
