how to check the function of the autronic eye in my '53 -98
Old Oct 21, 2013 | 03:38 PM
stocki26's Avatar
I am still working on my 98 - but I hope to get most things done this year : O
So I also want to test if the eye is working as it should
Seems to me as someone has repaired it not too long ago ..... I bought that 98 and have been restoring brakes, brake lines, some welding and so on the last months
Anyone here that can tell me how to check it at the parking car ?
Old Oct 22, 2013 | 07:36 AM
Basically covering and uncovering the eye will make the hi beams switch on and off I believe.
Old Oct 22, 2013 | 08:40 AM
I've heard that modern headlamps blind the autronic eye and the eye keeps the high beams off all the time. I had one on my 64 98 and it never worked correctly.
Old Oct 22, 2013 | 09:03 AM
stocki26's Avatar
there are two switches on the floor A and B
as far as I understand one is for manual Hi-Lo one is for Auto position of the eye
which is is for manual and which for Auto ? Is there any lamp that shows if Auto is on ?
has engine to run or should it work with battery also ?
is really no driving necessary for let it switch automatically ?
Old Oct 22, 2013 | 10:19 AM
One switch is an override the other is the stock switch. Look for the single wired switch, that is the aux.
Old Oct 22, 2013 | 12:25 PM
stocki26's Avatar
Thumbs up
wow, very nice .... thank you very much - this will help for sure !
Old Oct 22, 2013 | 07:11 PM
redoldsman's Avatar
Proud Viet Nam Veteran
The lights in my garage will make mine dim. I flashlight will do the same. The engine does not have to be running. The small switch is an override to flash your lights if an oncoming car fails to dim their lights.
Old Sep 4, 2017 | 11:55 AM
stocki26's Avatar
is anyone able to show pictures from inside the autronic eye ?
It would be great for me to see what is inside - how I could open mine if it is necessary and which parts are inside that "see" the light and switch off mine
Old Sep 6, 2017 | 06:52 AM
Rocketowner's Avatar
My mother had a '55 "98 " when I was young,that had the autotronic eye . On one occasion I was riding with her on a stretch of road that was similar to a roller coaster(very hilly and curvey ) ! It was a very bright moonlight night, and when we would top a hill , the lights kept brightening when the moon would shine into the autotronic eye . They were very sensitive to light, but a neat accessory. Larry
Old Sep 9, 2017 | 04:32 AM
Ozzie's Avatar
I don't have the shop manual for the 1953 Oldsmobile, but in the one for the 1955 there are three pages in the electrical section describing how to aim and adjust the sensitivity of the Autronic-Eye. It's on pages 385 through 387 (or 13-47 through 13-49) in the 1955 shop manual. The one for 1953 will likely be similar. A simplified wiring diagram for the Autronic-eye is shown with the wiring diagram for the rest of the car.
On pages 33 & 34 of the 1955 Oldsmobile owner manual there is a description of the function of the Autronic-eye. It describes everything that is needed to know how to correctly operate it.
Old Sep 9, 2017 | 09:46 AM
redoldsman's Avatar
I have never opened mine up. The guy I bought it from converted it to solid state so it has none of the vacuum tubes in it. Although it works well, living in a major metropolitan area I rarely use it. It is mostly a novel addition to the car and occasionally somebody at a car show will ask what it is.
Old Sep 11, 2017 | 01:08 AM
stocki26's Avatar
I am a technician and would love to see what is inside and how it works, just to understand what they built in '53 and how the system works.
For example I did not know that there are vacuum tubes connected to the autronic eye, or did I understand that wrong ?
Old Sep 11, 2017 | 08:15 AM
Tedd Thompson's Avatar
Vacuum tubes like old radio tubes not like manifold vacuum tubing if I'm understanding your confusion or is it me that is confused... Tedd
Old Sep 11, 2017 | 08:27 AM
stocki26's Avatar
ok, now I can hear you LOL you mean that :
belgium57olds
Mar 3, 2013 04:57 AM
deaddds
Ninety-Eight
Feb 2, 2013 08:43 AM
67 Cutlass Freak
May 5, 2012 09:31 AM
hialeah56
Oct 25, 2009 06:02 PM
