dash removal
Old Aug 11, 2013 | 07:14 AM
back2life's Avatar
dash removal
hi guys i have a 69 olds 98 that i need to put a headlight switch in and i need help with how to take apart the dash area so as i dont break stuff. also i need to kno does anyone have a vacuum routing for this car or motor (455)?
Old Aug 14, 2013 | 11:18 AM
rocwal's Avatar
68 headlight switch
. start under dash ,on top and near dash the switch has a small push down button to release the **** and stem , off hand I think you have to turn switch **** to dimmer , push down on button , twist the **** and pull it out of switch . then remove the etstuction nut , pull switch out from back of dash , unplug wire harness on switch. recommend disconnect the battery first to prevent shorts. A manual has all the information needed for repairs and diagrams .
REVISED .I just took one out of a dash that is in storage and the button is on the bottom of switch .
Dan B
mrnursedude
Nov 12, 2019 03:27 AM
Bryan59EC
Jun 3, 2010 10:36 AM
77 oldsMAbrotha
Sep 23, 2008 05:00 PM
dholmes898
Jul 9, 2007 09:13 PM
mich77442
May 14, 2007 11:39 AM
