'72 Ninety Eight wheel & tire size
Would a 235/75-15 tire on a 15x7 wheel (5x5 BC, 80s Chevy 9C1) be a good fit relative to brake and fender/wheelwell clearance for a '72 Ninety Eight?
OEM was a 225/75-15 on a 15x6 (5x5 BC) wheel, correct?
Last edited by lsutigers93; February 8th, 2012 at 11:11 PM. Reason: Left out something
Civilian 15x7" 4 1/2" backspacing
9C1 15x7" 4 3/8" backspacing
Suburban rims
15x6" 3 5/8" backspacing
15x8" 4 1/8" backspacing
Compare this to your stock backspacing, and see what you come up with.
ALSO...
I have no idea how different the center bores are, but they should be ok. I used a 70's wheel on a 90's caprice as a spare once, but i used it in the front.
Suburban rims
ALSO...
Hmmm...ok. Standard wheels and hubcaps with whitewalls (Firestone FR380} or body-color GM truck rallys (15x8) with rings and caps (rocket logo, natch!) with whitewalls??
Last edited by lsutigers93; February 11th, 2012 at 09:03 PM. Reason: Deleted wrong color name
This would be Saturn Gold Poly, correct?
I will have to get the codes (don't physically have the car yet)...just want a little wider wheel and a little different look, just rattling ideas around in my head. Don't worry, I'm not going to donk it out
The original tire was a J78 x 15. Your best match is a 235/75 x 15. My 68 Delta had 14 x 6 rims that I switched over to 15 x 7 rims last summer. I put Firestone FR380 on the car. No issues other than replacing my wheel covers. Dramatic improvement over the bias belted tires that I replaced
76 Regency
June 5th, 2015 02:48 PM
Baugher Garage
Wheels and Tires
October 3rd, 2011 07:19 AM
oldscruiser
Ninety-Eight
September 1st, 2010 08:20 AM
Wil Lopez
Ninety-Eight
August 29th, 2010 09:41 AM
jburns84
July 26th, 2010 07:19 AM
