70 olds 98 posi in open carrier?
Old May 2, 2012 | 04:43 AM
ptilden's Avatar
does the posi unit from a 70 98 fit a 70 98 open carrier? Any parts kits for the swap? What parts might I need if it does fit? Thanks
Old May 2, 2012 | 09:22 AM
oldsmobiledave's Avatar
tech & terminilogy
Your question is confusing because you are not using the correct terminology.
What do you mean by posi UNIT?....what is a unit? Do you mean the entire posi carrier?
You mention the open carrier. Now this is a correct term. You can remove the open carrier from your differential & remove the gear set. You can then install this gear set onto a posi carrier & reinstall it into your differential. You will now have a posi rear end.
Old May 2, 2012 | 10:00 AM
ptilden's Avatar
thanks for the info.
Old May 2, 2012 | 09:07 PM
2blu442's Avatar
As far as parts go 507OLDS and monzaz are both members here whom I consider experts with rear diff's. In addition they both buy/sell/trade parts to complete rear ends. I'd encourage you to contact either one of them to see if they have what you need or could point you in the right direction. Good Luck with your project! John
wildcatmom
Sep 3, 2013 05:06 PM
507OLDS
Oct 3, 2012 10:45 AM
warrior71
Jun 13, 2012 08:59 PM
4fortwo
Nov 22, 2008 10:02 AM
