1993 Olds 98
Old April 15th, 2021 | 01:27 AM
TheRealMcCoy's Avatar
1993 Olds 98
Does anyone know the story on this top?
Was it rare?
1993 Oldsmobile 98
1993 Oldsmobile 98
Old April 15th, 2021 | 06:27 AM
That is a dealer installed top or aftermarket. As far as I know, the 91-96 98s weren't offered with a vinyl top from Oldsmobile.
Make sure the cooling system is in good repair on your 98. The 3.8l v6s used DexCool coolant and it has a tendency to gel and clog the radiator and water jacket. Unfortunately you can't change to traditional green coolant unless you rebuild the engine and swap the radiator/heater core.
Old April 16th, 2021 | 05:58 AM
That is a beautiful Olds!
One of our other members; Allan R, drove a late model C body 98 in the past. He speaks highly of them. I drive my 96 98 every day 70+ mile to and from work. I generally get 21+ mpg.
Does your Olds have leather or the supercharged engine? I drove to Houston, TX to buy my 98. Let us know if you have questions.
Old April 16th, 2021 | 07:54 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Those tops were often referred to as Carriage Tops back in the day. Senior Citizens loved them and they often were accompanied by gold trim. I referred to them as the Senior Citizen Package. They usually had a fiberglass shell that was installed and the top was installed over that. They were not cheap and I think cost something like $1,500 at that time.
Old April 16th, 2021 | 09:09 PM
Thanks for the feedback. Great information.
The interior is going to clean up nicely. It is leather.
Old April 17th, 2021 | 11:02 AM
gkhashem's Avatar
I do not think the 1993 had Dex-Cool my 1992 does not. I think that started in 1995 or 1996.
Old April 17th, 2021 | 04:43 PM
If his 3.8l doesn't have DexCool that's excellent!
Old April 17th, 2021 | 05:20 PM
gkhashem's Avatar
Introduced by GM in 1995.
https://www.hemmings.com/stories/art...like-a-rainbow
Really Dex-cool is not the issue its the intake manifold gaskets. Change them and you are all set. Spend the $800 or so and do it. If the car is good it will rust first before the engine dies.
Old April 18th, 2021 | 05:37 PM
blakes7's Avatar
I've replaced the dex cool with green Prestone in two different 2007 GM cars and had no problems for several years now.
Old April 22nd, 2021 | 05:49 PM
1993 Oldsmobile 98 Regency Special Edition. Leather interior, rear window defroster, power everything.
Old April 23rd, 2021 | 06:51 AM
I like those wheels better with the paint/powder coating in the center and the polished trim ring vs. the satin aluminum wheels available on the 91-96 98s. It matches the padded vinyl top.
junker garage
April 20th, 2019 06:52 AM
wfrs2007
Ninety-Eight
July 26th, 2007 03:35 PM
