1968 Olds 98 new wire wheels
I had ordered Kelsey-Hayes wire wheels back in Aug 2021. They finally arrived after almost 7 months. Attached are pictures of my Olds with the 15x7 wire wheels. I mounter American Classic 225-75-15 tires that have 1 3/8" wide white walls.
Yes, the wire wheels are from Truespoke. The rocket emblem was one of the two choices for the center cap. I don't know if they have knock-off rims.
Spacer for the front wheels
After I installed the wheels, they was severe vibration in the front while braking. No vibration when crusing. When I consulted my mechanic, it was deemed necessary to install a 1/8" thk spacer in the front. As you can see from the picture of the front brake drums, the wire wheels were not flush.
Front brake drums
1/8" thk spacer
This solved the problem
Front brake drums
1/8" thk spacer
That's odd that you got the vibration only while braking and that a spacer fixed the problem. Were the wire wheels you got 5x5" bolt pattern, or did they have oblong bolt holes with spacers? I know you can buy Cragars that fit both the 5x5" and 5x4.75" bolt patterns.
Here are some knock-off Daytons offered by Truespoke:
https://www.truespoke.com/dayton-wire-wheels
BTW, I think those white walls are bad@$$! Were the American Classic white walls part of a package from Truespoke?
