1964 Olds 98 windshield washer pump
Old Apr 28, 2018 | 09:00 AM
gkhashem's Avatar
My motor works, seems the pump worked for a while after a new pump kit then stopped even though I can still hear it pumping.
Any thoughts, when I took the pump off and turned it by hand seemed to squirt some. Anything going on between the motor and pump?
The wiper motor works. I have also checked the hosed and reservoir and changed the feed line from the bottle.So it is not the obvious issues that could be the problem.
Old Apr 28, 2018 | 04:58 PM
Rocketowner's Avatar
Seems like the problem might still be in the pump itself. I 'd pull it back apart and check the diaphragm and O-rings and look For a tiny hole in the diaphragm or a O-ring not seated properly. Hope you find the problem, Larry
Rocketbrian
Mar 31, 2018 05:08 PM
joesw31
Jan 16, 2017 08:01 AM
need4speed
Apr 5, 2014 02:14 PM
DeltaDevil88
May 27, 2011 08:41 AM
bjtstarfire
Jan 24, 2008 10:42 AM
