1964 olds 4dr rear end
Old Mar 2, 2008 | 07:07 PM
pimps1002's Avatar
hey just tryin to figure out somthing on this 1964 olds 98 i just picked up. it has a ford 9 or what looks alot like it under it its a total factory rear end just wondering if olds made a rear end that looked like a 9, and if any one could give me any info on this car i believe its a 4dr sports coupe or maybe they call it a 4 dr hard top, its a pillarless car just wondering how many were made like this any info would be nice thanks
Old Mar 2, 2008 | 07:23 PM
rocketraider's Avatar
Oldsdruid
It's similar to the 9" Ford, and if anything tougher. Just no aftermarket support now, though it was the rear of choice for hardcore drag racers for years. Used 1957-64 on Olds and Pontiac. You probably have 3.08 or 3.23 gears in there, possibly 2.93's.
You could have a Holiday Sports Sedan (24791 built) or a Luxury Sedan (17346). Luxury Sedan has a small window behind the rear door glass.
Old Mar 3, 2008 | 02:49 PM
These are the best cars ever! I own a 1964 Olds 98 Luxury Sedan. It is awsome driving it during nice weather with the windows down.
Old Mar 3, 2008 | 03:53 PM
pimps1002's Avatar
thanks for the info. it doesn't have a small glass behind the rear door. so i guess its a holiday sports sedan. and im looking for a brake booster for this thing its out and this thing aint too easy to stop with out power brakes. thanks again
Old Mar 3, 2008 | 04:05 PM
Oldsdruid
You're about to find out about Oldsmobile's different suppliers.
64 big cars could have Moraine or Bendix power brakes, and master cylinders and boosters do not interchange between the two.
Easiest way I know to tell the difference is the Moraine booster is physically larger and has dimples on its face, and the MC cap is held on with a wire bail.
Bendix booster is smaller, smooth faced and MC usually have a screw-on cap. The Bendix is way easier to find at the parts store. You'll probably have to order it thru CarQuest or NAPA. A big discount chain won't have a clue what you need.
Make sure the vacuum check valve on the booster is in place and functional. You may also have a frozen wheel cylinder on one wheel which will make you think the booster's gone out.
Old Mar 4, 2008 | 08:24 AM
Modern Motoring's Avatar
Booster dewey ! http://boosterdeweyexchange.com/
Old Mar 4, 2008 | 07:30 PM
pimps1002's Avatar
thanks again for the info, and i was wondering what did Oldsmobile call their rear end that looks like the ford 9 just for later on down the road if i need to rebuild it thanks
Jandk
Jul 4, 2015 11:45 PM
lindaledft
Sep 15, 2014 06:03 PM
350TurBRO
Sep 12, 2014 11:52 AM
JATA
Sep 23, 2013 04:58 AM
JATA
Sep 3, 2013 08:18 PM
