1964 Clock Removal
Old May 9, 2017 | 03:05 PM
gkhashem's Avatar
1964 Clock Removal
I have worked on Cadillacs before and the manuals seemed more detailed. I have the 1964 Olds manual but it is vague on this.
It says all instruments can be removed with removing the lower panel, OK so how do I get the clock out.
It looks like the clock is attached to the bezel by three nuts from the rear. So i remove them and the bezel should come out with the clock attached to it.
Do I have it correct?
Thanks for any help,
Old May 10, 2017 | 09:59 AM
D. Yaros's Avatar
Not at all familiar with the 1964, but do have a 62, which I suspect is similar. On mine there are 3 screws that hold the clock in; 2 at top, 1 at bottom.
o----------o
------o-----
Remove them and the clock comes out from the front of the dash after the wiring is disconnected.
Old May 10, 2017 | 02:19 PM
gkhashem's Avatar
Yes there are 3 screws and 3 loops that they go through but the dash bezel is in the way
Does the bezel come off first or do I pull clock out from rear?? So are the screws in the bezel or the dash itself. Diagram looks like bezel
Old May 11, 2017 | 11:31 AM
D. Yaros's Avatar
Is this your dash?
g[/url]
I would think the clock and surrounding bezel should come out, from the front, w/o having to remove anything other than the wiring and the 3 holding screws. I would also think the clock should come out from the front.
Old May 11, 2017 | 04:45 PM
gkhashem's Avatar
The bezel is the whole piece in the middle includes the Starfire plate and around the speedo.
So I am puzzled.
Old May 12, 2017 | 12:17 PM
D. Yaros's Avatar
I am not able to answer your questions any further, not being familiar with the 1964 dash. Hopefully someone with a '64 will jump in and provide you with the info.
My suggestion is undo the retaining screws and see what the situation is then. That will tell you what more is, or is not, required to get the clock out. It is not likely that doing so will hurt or break anything.
From what I can tell the housing for the clock is black.
If that is correct, it would then remove from the back of the dash, as once installed it has a chrome surround.
With that, I have nothing further that I can add. Sorry.
Old May 13, 2017 | 05:15 AM
gkhashem's Avatar
That's the clock
Old May 14, 2017 | 11:15 AM
rocketraider's Avatar
Oldsdruid
Take out the glovebox and A/C duct if needed, reach up cattawampus behind the dash, undo the three screws and remove clock from BEHIND the dash. You will swear and scratch your arms up, but that's how it's done.
Old May 14, 2017 | 11:58 AM
gkhashem's Avatar
are they nuts or screws , if screws how on earth do you do that?
Sorry but the manual is real poor implies the clock is screwed into the bezel
wonder if I take the bezel off
Old May 18, 2017 | 02:43 PM
Oldsdruid
Sorry- they are nuts. 1/4" drive ratchet with a short wobble extension should get them out for you. Can't remember what size the nuts are but 1/4", 9/32" or 5/16" sounds bout right.
Bee Saint Louis
Jun 25, 2016 09:13 AM
JOHNNYOLDS442
Nov 19, 2015 07:39 PM
lakidd135
Aug 5, 2009 09:43 AM
68Tom
May 26, 2009 01:09 PM
Furr442
Jan 29, 2007 06:02 PM
