72 Cutlass speedometer
Old Apr 1, 2015 | 04:13 PM
MattP_15's Avatar
I just bought a 1972 cutlass speedometer off eBay and the odometer is reading 30k miles. Is there any way to zero out the odometer?
Old Apr 1, 2015 | 04:25 PM
RetroRanger's Avatar
72 Olds CS
yes you can take it apart and reset the odo counter...I dont recall if there were pics on here or not, if not maybe i saw it in the CSM ?
Old Apr 1, 2015 | 04:38 PM
tdhill01's Avatar
Check with Scott - oldspackrat
Old Apr 1, 2015 | 05:04 PM
This vid shows the procedure. Easy enough but take your time. Yeah this says Mustang, but it's the same for GM.
Old Apr 2, 2015 | 06:48 AM
I've done this many times. I'll add that there are thin plastic strips between the wheels on the odo drum that lock the wheels in place. Be very careful not to break these strips, and to get them back into place properly. Other than that, it's pretty easy.
Old Apr 2, 2015 | 09:46 AM
If the numbers need freshening they can be obtained from Bob's Speedometer (it's a tape on over top of the old ones. Usually it's the '10'ths that turn yellow instead of staying white.
70 ctls
Dec 8, 2012 11:33 PM
69442
Oct 12, 2010 05:50 AM
jdana24
Apr 13, 2010 09:18 AM
we jeep inn
Feb 9, 2010 04:29 PM
ros6872
Feb 8, 2010 08:35 AM
