block numbers
Old Jun 9, 2014 | 11:24 AM
jj442's Avatar
Exclamation block numbers
can someone help me? I have a 1972 442, the block casting numbers is 395558-2 and the head number is 3A. the motor is said to have been redone when I got it. it has a four speed manual in it, and ***** in gets but when I get it up to about 70mph it seems to redline but I have so much pedal left what can I do to fix this
Old Jun 9, 2014 | 11:31 AM
LoganMiller68's Avatar
It's redlining in 4th gear at 70? And what do you mean by 'seems to redline'.
Old Jun 9, 2014 | 11:44 AM
jj442's Avatar
yes, in 4th gear. the rpm is way to high. seems like if I stay in it something will give way. motor has been mod but don't know if the rear end has been done or not
Old Jun 9, 2014 | 11:48 AM
jj442's Avatar
it has a 350 motor in it with 455 vale heads, at least that's what I was told
Old Jun 9, 2014 | 12:03 PM
Originally Posted by jj442
... the block casting numbers is 395558-2 and the head number is 3A.
The block is a 350 from earlier than '77, and the heads are '77-'80 350.
... when I get it up to about 70mph it seems to redline...
Seems to? What exactly does that mean.
Either it redlines or it doesn't redline.
And where exactly is your redline?
... I have so much pedal left
What does this mean? Are you expecting that if the pedal goes down farther, the car should go faster?
Well, the heads are from a 350, so they're not 455.
If you mean that someone installed larger valves in the heads, the 455 came with a variety of them over the years, so it might be helpful to know which ones were installed.
You may need to take some things apart, so you can figure out what you have, so you can get it tuned and set up properly.
Old Jun 9, 2014 | 12:31 PM
jj442's Avatar
yes it has bigger valves. also the car will go faster but starts to heat up. temp sits at 190 at 70mph with rpm at about 6rpm but when I start going faster temp starts to rise to about 200 degrees and motor sounds like its redlining. also the gears seem real short.
Old Jun 9, 2014 | 12:57 PM
pogo69's Avatar
morgan
what rear end is in it
Old Jun 9, 2014 | 01:25 PM
jj442's Avatar
not sure, but maybe I should start there with the rear end. I do know its not a posi
Old Jun 9, 2014 | 05:01 PM
... the car will go faster but starts to heat up. temp sits at 190 at 70mph with rpm at about 6rpm but when I start going faster temp starts to rise to about 200 degrees and motor sounds like its redlining.
So you're saying that some part of the current cooling system is inadequate.
Time to go through and check the radiator and water pump, make sure the lower hose doesn't collapse at high RPMs, and make sure the inside of the motor isn't scaled up.
A high-flow thermostat probably wouldn't hurt either.
Now back to the previous question:
What the heck do you mean, "motor sounds like it's redlining"?
What does a motor sound like when it's "redlining"?
Never mind the sound, Is the motor actually redlining?
How fast is the motor revving when this sound occurs?
What is this motor's redline?
Old Jun 9, 2014 | 05:31 PM
jj442's Avatar
sorry Eric, but I don't know the motor redline. I just think by the gears being so short that the rear end may be geared wrong making it red line and the rev real high at 70 mph. I may just take it to the speed shop and have a bigger gear put in it. thanks guys for your help I will let you know how it turns out
Old Jun 9, 2014 | 06:15 PM
For the love of all that is holy and burns oil,
HOW FAST IS THE ENGINE TURNING AT 70 MPH ?
What does a guy have to do to get an answer to a simple question around here, especially one that is directly related to the poster's query?
Old Jun 9, 2014 | 06:18 PM
billmerbach's Avatar
major noob
Eric calm down deep breaths lol
Old Jun 9, 2014 | 07:12 PM
Octania's Avatar
Heh
Lack of Communication, lack of.
nice call mr merbach
simma donna
Old Jun 9, 2014 | 07:17 PM
steverw's Avatar
Do you have a tachometer? if so you can read the RPM'S from that to know if its redlining or not. You said at 70 mph its running about 190 degrees and the motor is turning 6 rpm. That 6 rpm is times 1000 so your turning 6000 rpms, IF your reading this off of a tachometer. If this is so then you dont want to go any faster as your motor has reached its peak RPM. Any faster for a prolonged period of time could destroy the motor. Most Olds motors dont wind up like Chevys do. And i would say 190 degrees at 70mph and 6000 rpms is not bad. It sounds like you have a LOW geared rearend. The bigger number like 3.90 or 4.11 the lower the gear. A low number like 2.73 would be a higher geared rear which will let you go 70 mph and keep the RPMS down lower, thus much farther from REDLINING. Now im no pro and theres plenty of guys here that know more than me, im just trying to explain some things to you. There are several ways to determine your rear gear ratio, one is to get the numbers off of the ring gear in the rearend, the other im not familiar with, turning the rear wheels and counting driveshaft revolutions. Maybe someone will explain that to you.
Old Jun 9, 2014 | 07:22 PM
Octania's Avatar
My 85 442 with OD trans and 3.73:1 gears goes about 2700 RPM at ~70 mph.
If you cannot go faster than 70 because your engine is maxed out at RPM at 6000, your must have hella gears like 4.33... or try shifting out of 2nd!
Old Jun 10, 2014 | 07:00 AM
..at 70mph with rpm at about 6rpm..
I think is the answer you're looking for MD.
JJ it sounds like your gearing is off then. I have no idea who teamed that transmission with that rear-end ratio, but 70 at 6krpm in 4th gear is nuts.
I'd start by seeing what your rear end is first and go from there.
Also, don't stay up in that RPM range for long in an Olds engine. Unless you like to grenade your block
Old Jun 10, 2014 | 07:48 AM
... rpm at about 6rpm ...
OMG, I completely missed that.
Wow, it's like telling time: "The little hand is on the one, and the big hand is on the five." --
The red needle is pointing to the six, so he must be turning 6 RPM.
How cute.
Okay, let's just calculate this out.
The OP has not told us his tire size, but standard tires on a '72 A-body were about 225/70x14, which have a circumference of 83" and turn 764 times per mile.
764 revs per mile times 70 miles = 53,480 revolutions in 70 miles.
This means that if he drove 70 miles in one hour, the rear tires would go around 53,480 times, so if we divide by 60 minutes in an hour, we get 891 revolutions per minute at 70mph.
If he tells us that he is turning 6,000 RPM at 70mph in top gear (1:1 ratio, unless he has an overdrive top gear ), then 6,000 ÷ 891 = a 6.73:1 rear end.
Methinks something here is not quite right.
Old Jun 10, 2014 | 11:37 AM
4speed455's Avatar
Check the vacuum line on the tranny. I had mine pop off and I was turning about 6k rpm at 70 because the tranny wasn't shifting.
Never mine just re-read the op has. A 4 speed.
Old Jun 10, 2014 | 12:11 PM
How cute.
Yeah, something is way off
Old Jun 10, 2014 | 05:35 PM
2Olds4U's Avatar
Majored in rear tire demo
It sure is. His clutch is gone.
Old Jun 10, 2014 | 05:45 PM
Could be. You'd think he'd smell it, though... Or were you speaking figuratively?
Old Jun 11, 2014 | 07:52 PM
2Olds4U's Avatar
No, Eric, quite literally. What other explanation for his symptoms?
I've driven plenty of cars with bad clutches that didn't smell unless they were severely over heated. I don't know anything about the OP's experience with sticks or his mechanical knowledge to make a decision about him.
Paul
Old Jun 11, 2014 | 08:25 PM
Hey, could be, but in my own experience, any time i had a slipping clutch, it was obvious, and I definitely smelled it whenever I got on it.
That and the tachometer that tended to wander upward were quick giveaways.
But okay, it's possible.
'Course, I'm going with the figurative meaning...
Old Jun 13, 2014 | 05:42 PM
2Olds4U's Avatar
but when I get it up to about 70mph it seems to redline but I have so much pedal left....
The OP states the tach is way too high. I stand by my statement.
Paul
jawsmon
Jul 13, 2012 07:17 AM
JBishop
Jan 17, 2012 08:28 PM
bluecab
Apr 20, 2011 05:26 AM
BigBertha442
Jul 9, 2009 11:18 AM
tobipaint
Jul 11, 2007 10:48 AM
