VIN number
From: Alsterbro/kalmar-Sweden lok.56.944623,15.913353
VIN number
Hey. Now it gets a bit tricky. I am a Dane living in Sweden. I bought a 75 Cutless with VIN Jk5TK5M248991 It is sold here in sweden, new in 75. Now comes what is a bit tricky. I went in on http://www.v8cars.hu/oldsvin/vin.php and when i write my VIN number, I get the following message:
Please note:
A VIN never contains the letters 'I', 'O' and 'Q'.
1946-48 VINs are 7 or 8, 1949-60 VINs are 8 or 9, 1961-1963 are 9, 1964 VINs are 10, 1965-80 VINs are 13, and VINs 1981 to present are 17 characters in length.
The vehicle year must be 1946 to 1997.
What am I doing wrong? : Pleace be nice to help a new member and an old guy
Please note:
Please note:
Please note:
What you're doing wrong is misreading the VIN. Here's the official GM VIN card for your year that decodes the VIN:
http://service.gm.com/dealerworld/vi.../vincard75.pdf
From the VIN card, we get:
J = GM Division. This is always a digit, unless there's something unique about European cars. Verify that this really is a "J", as it should be a "3" for Oldsmobile division.
K = Model - Cutlass Salon Colonnade
5T = Body Type. Again, these should be two digits. I suspect that it's really "57", which would be a 2 dr hardtop
K = Engine - 350 4bbl with 170 net HP
5 = Model year - 1975
M = Assembly Plant - Lansing, MI
248991 = sequential build number
First of all, that's not an Oldsmobile VIN.
Oldsmobile VINs start with "3" in 1975.
So,
Look at your VIN again and see what the numbers really are.
edit: Joe, you beat me to it!
So,
- First digit: J≠3
- Second digit: K = Cutlass Salon
- Third and fourth Digits: Indicate body style. There is no 5T, but 57 would = Hardtop Coupe
- Fifth digit: K = 350, 4bbl carburetor
- Sixth digit: 5 = 1975 model year
- Seventh digit: M = Lansing assembly plant
A "normal" US built 1975 Oldsmobile's VIN starts with a "3" & is 13 characters long.
3J57K5M248991 would be a "normal" VIN for a '75 Cutlass Supreme 2 dr. w/350 4bbl.
If the VIN posted is accurate:
WAG - this is a "Knock Down" vehicle that was shipped to SWEDEN for final assembly.
JK5TK5M248991 (is the 4th digit a "7"?)
J = Cutlass Supreme
K = "knock down" ???
57 = 2 dr. coupe
K = 350 4bbl single exhaust
5 = 1975
M = Lansing, MI assembly plant
248991 = VIN sequence number (148991st assigned VIN)
J = Cutlass Supreme
57 = 2 dr. coupe
5 = 1975
[QUOTE=joe_padavano;626246]Welcome. By the way, it's a Cutlass, not a Cutless.
You were right ;-)
You were right ;-)
So,
So,
- First digit: J≠3
olds53rocket
Dec 22, 2006 05:46 PM
