Trans TH400 ? about vin number on it?
Old Feb 29, 2008 | 06:27 PM
BigBertha442's Avatar
here is the vin number?
can anybody tell me what yr? and body style?
21X327448. It is a TH 400
not sure if it is a 71 or 71 and does the X mean a W30 car?
Old Feb 29, 2008 | 06:35 PM
don71's Avatar
same but different
The X should indicate assembly plant, in this case Kansas City MO...er or was it Kansas....?
Old Feb 29, 2008 | 06:38 PM
71 or 72?
Old Feb 29, 2008 | 06:50 PM
don71's Avatar
same but different
Since the second digit is a one, I would say its a 71.
Also I'm NOT sure that is a OLDS th400 the first digit is a 2 it should be a 3
You got this number from the drivers side just above the pan...right?
Do you have the two letter code and numbers form the RIVOTED tag?
Old Feb 29, 2008 | 07:10 PM
yes here it is
The tag on the back of the trans has the following numbers:
71 - PA - 32037
Old Feb 29, 2008 | 07:21 PM
don71's Avatar
same but different
That indicates a 1971 pontiac, installed for their 455.
The other numbers are the serial number for THAT trans.
Sorry, my book does not list model of vehicle. I would guess to say that is a very common calibration (valvebody) used in many models.
My olds has a 78 pontaic 400 trans.....and its been a good one. So no problem there....good luck.
Old Feb 29, 2008 | 07:30 PM
does anybody have a 1972 olds TH400 for sale?
I have a olds TH400 from 1979 but want to have the correct yr for my car.
If all other numbers match on the car except the trans can it still be a numbers matching car?
Old Mar 1, 2008 | 08:10 AM
Nice try. The "X" for the W-30 engine only applies to the engine code used in the full VIN and only for the 1972 model year. As noted, in this VIN derivative the "2" indicates Pontiac division, the "1" indicates 1971 model year, and the "X" indicates the Kansas City, KS factory. Since KC only built full size cars, this trans likely came out of a Bonneville.
71 - PA - 32037
The "71" also indicates 1971 model year. The "P" in the "PA" indicates Pontiac (just as the "O" in OW, for example, indicates Oldsmobile). The "A" would likely provide info as to the engine it was bolted to, but I don't have the listings for 1971 Pontiac transmissions.
Old Mar 1, 2008 | 08:16 AM
Thanks!!!!
Alg
Jan 1, 2013 05:04 PM
ls442
Nov 11, 2010 10:45 PM
jrblanke
Dec 25, 2007 01:49 PM
1972madison
Aug 3, 2007 06:35 PM
olds53rocket
Dec 22, 2006 05:46 PM
