1969 442
Just finished a frame on restoration of an original 1969 convertible 442 and am trying to find out production numbers. Anyone have an idea of how many convertible 442's were built in 69 but here is the catch, this one came through with a floor mounted standard Saginaw 3 speed trans. The engine is the original 400 V-8, 4 barrel, with dual exhaust. Have heard everything from 90 to 1250 were built. Thanks!
Total production of '69 442 convertibles was 4,295. My source doesn't break it down by how many had that transmission. Maybe someone else will have that info.
Can we see photos of this car?
3 speed
Are you sure that 3 speed on the floor was a Saginaw & not a Dearborn?
Here are a few shots of the car. Potential buyers have been asking and I have been reluctant to offer numbers other than, like you wrote, the total produced! Thank you
saginaw vs dearborn
It's such an issue to have firm concrete answers on some of these issues as the records are poor and in some cases unavailable. One nice thing about the Pontaic Historical Society (PHS) submit a VIN and get a full report! Several on line sources state the Saginaw as the floor mounted but also available as a column mounted, so this is why I put the question out there!
Nice '69!
There were 87 1969 442s Convertibles that came with a 3-speed manual transmission.
I have one and knew of 2 others. Now I know of 3 others. If your trans is original, then it is not a Saginaw, it is a Ford toploader. One can call it a "Dearborn" trans, but it came from Ford.
Thank you, 87 is the number I have heard but did not want to provide incorrect info to a possible buyer as this car is for sale. Might I ask, where di you find the production numbers should I be asked?
These are fairly well distributed figures that originally came from Oldsmobile and were originally compiled by Helen Early. They are still kept as "official" numbers by the GM Heritage Center.
As for rarity, some things are rare for a reason. The three speed manual was unpopular when these cars were new. People upgraded to the four speed or the automatic.
Every one makes a blunder here or there! He wasn't the only one to call it a Saginaw!
Very true about rarity...but..some of the rarest and ugliest are now sought after !!
Thanks for the input
If I could order a new GTO, 442, or GrandSport today, and I wish I could, I would order the base 3 speed manual transmission. I had a couple GTO's and a W-31 Olds with four speeds but enjoyed the Dearborn 3 speed car more.
The toploader 3 speed Dearborn manual transmission was one of the toughest and best shifting manual transmissions GM used in those days. It was the transmission Ford developed to use behind their big block cars around 1963 as I recall. Stock car race drivers choose these transmissions for their dirt track type cars today I understand because of its durability.
crystal59
July 6th, 2023 04:39 PM
halfmoontrail
August 31st, 2013 09:05 PM
mcutlass1969
Drivetrain/Differentials
February 12th, 2008 08:59 AM
