Jetaway
Old Mar 29, 2013 | 12:49 PM
ironlou399's Avatar
Jetaway
In 1966 there were 4 V-8 Jetaway trannys(ML 330 2bbl,MK 330 4bbl,MT 330 Jetstar 88 and NJ 400 4bbl). Would the 400 cid Code NJ fit on the 330 cid engine?
Old Mar 29, 2013 | 02:55 PM
Octania's Avatar
"fit on"?
as in bolt up to w/o hassle?
YES, GM transes exc. brand C are very interchangeable.
Jetway to jetaway you should not have ANY issues like electrical vs cable kickdown, overall length [therefore driveshaft length], fill tube location and shape, selector attachment, nothing... easy as pie. Both should be Switch Pitch.
If you don't know how to tell, do a search here, at ROP, and on the net in general....
Old Mar 29, 2013 | 03:14 PM
ironlou399's Avatar
What is ROP?
Old Mar 29, 2013 | 03:37 PM
The only thing I'm not sure of is the tailhousing length on the J88 versions of the Junkaway, er, Jetaway. Other B-body transmissions were typically long-tail versions, whereas the A-body cars used the short-tail transmissions.
Old Mar 29, 2013 | 04:15 PM
Charlie Jones's Avatar
Phantom Phixer
I checked in the Olds parts book and it says;
Group 4.317 Extension, Trans housing (Tailshaft housing )
64-69 F-85 J.T. (Jetaway) 6260035
65-68 J.T. Except F-85 1368637
From this it can be inferred that since the tail housings are different, It is probably due to their length.
I know from experience that TH 350's had two different lengths depending on which body (AorB).
ROP = Real Olds Power. Another Olds oriented websight.
dynamic88
Apr 23, 2015 05:30 PM
dallas6778
Oct 15, 2008 10:59 AM
big-al-D-88
30
Dec 2, 2007 01:09 AM
clloyd
May 12, 2006 07:28 AM
<Derek Anthony>
Nov 26, 2005 05:14 PM
