automatic braking
Old Jun 14, 2011 | 07:28 PM
olds57's Avatar
automatic braking
I have a 1957 olds s88 with a power brake problem.
problem is brakes come on by them selves and keep tightening as i roll along to the point that the car will not move until every thing has cooled down. Brake system is bendix power,system was completely rebuilt.Any idea of what my problem is?
Old Jun 14, 2011 | 08:32 PM
64Rocket's Avatar
Check the routing of your brake lines. Sounds like something is to close to a heat source. Did you do an engine change? Check around your exhaust sys, being to close to a brake line.
Gene
Old Jun 15, 2011 | 02:54 PM
olds57's Avatar
Gene :Thanks for the info I will check these points out.
Mike
Old Jun 15, 2011 | 02:59 PM
Oldskeeper's Avatar
I had a similar problem with my 63 and the booster was leaking and the vacuum was pulling the pedal down
Old Jun 16, 2011 | 05:59 PM
Oldsguy's Avatar
Past Administrator
Welcome to the site and hope you get the brakes fixed soon.
Old Jun 16, 2011 | 06:32 PM
jensenracing77's Avatar
i had this problem on a 62 dynamic 88 and it was the rod between the master cylinder and power brake booster was adjusted to tight. the brakes would not completely release because the piston in the master cylinder was not coming back far enough. as the brakes got hot it would just amplify the problem because any expansion of the fluid was not getting back into the reservoir. i adjusted the rod a little shorter and it fixed the problem on my situation.
Old Jun 16, 2011 | 07:13 PM
olds57's Avatar
automatic brake
Thanks Oldsguy for this interesting bit of information . I will look into this possibility it sounds like it could be my problem. I will let you know.
Thanks Mike
Freddy B
Aug 9, 2011 07:48 AM
VikingBlue
Jun 8, 2011 10:03 AM
al714
Oct 9, 2010 10:15 AM
Aceshigh
Oct 16, 2009 11:27 AM
DAN76
Brakes/Hydraulic Systems
Jul 28, 2009 02:13 AM
