New from Colorado
Old May 22, 2011 | 12:08 AM
sniswend's Avatar
New from Colorado
I have owned a 1971 Cutlass Supreme for over ten years now. Its triple black and has power everything. The car spent the 1990's as a drag car. I just pulled it out of storage, where it has been for the past 4 years, and I have some serious electrical issues with it. The positive wire that comes off the ignition coil started smoking when I started it up last. The wire burned all the way to the fuse box. I was just wondering if anyone on this forum has replaced a wire out of the fuse box, if so I would appreciate some advice.
Old May 22, 2011 | 06:09 AM
2blu442's Avatar
Welcome to the site! I'm glad your car didn't catch fire when it happened, have you identified where the short was? I've not changed wires out of the fuse box before, hopefully someone here has and can help. If you don't get a respose here try posting again under the electrical forum. John
Old May 22, 2011 | 06:42 AM
Oldsguy's Avatar
Past Administrator
It sounds like your distributor is damaged or the points were shorting the 12 volts to ground (which they actually are supposed to do but only momentarily). Here is an image that kinds of explains it. If your points are rusted/welded closed in some way or the distributor cam is not moving the points and they are in a closed position then they could be permanently closed, hence the short.
Old May 22, 2011 | 06:43 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO.
Old May 26, 2011 | 06:38 AM
CQR's Avatar
CQR
Welcome. I'm new here myself and in the Morrison area. Let me know if I can help.
Old May 26, 2011 | 07:58 AM
halffast's Avatar
Member
Welcome to the site. I live in the Franktown area. We would love to see some photos of your car.
Old May 30, 2011 | 09:42 AM
Mochi's Avatar
Welcome from Centennial :-)
Old May 31, 2011 | 12:53 PM
Tom442's Avatar
Welcome! fellow Denver Metro Oldsnut.
Old May 31, 2011 | 03:11 PM
toro68's Avatar
Welcome to ClassicOldsmobile!
Please let me know if you see and/or hear about a Cirtis Blue ( solid light blue) 1963 Starfire, that is the Blouder area.
Old Jun 5, 2011 | 06:52 AM
starr88's Avatar
also native coloradoen
welcome to site also new to site the guys are awsome about olds so any questions they sure can help i also know of about 3 parts cars in calhan so if your car needs something let me know the guy has 3000 cars so let me know if ant thing you need thanks
Tsandoval33
Oct 8, 2014 08:46 PM
CRockF85
Jun 21, 2013 06:25 PM
starr88
Jun 9, 2011 05:34 AM
caddy
Mar 24, 2011 07:20 PM
zodiacblueS
Mar 23, 2011 09:38 AM
