radiator
Old Mar 21, 2011 | 11:16 AM
antweave's Avatar
radiator
Why would a 2 or 3 core raditor run hot on a bone stock 455 engine(.30 over) in a 71 cutlass
Old Mar 21, 2011 | 11:26 AM
Lady72nRob71's Avatar
Not enough surface area to transfer the correct amount of heat from the coolant to the air.
A 2 core (row) would be the bare minimum for a stock 350 without AC or HD cooling.
A 3 core (row) would be the bare minimum for a stock 455 without AC or HD cooling.
A 4 row would be the best choice for any 455.
Old Mar 21, 2011 | 11:37 AM
svnt442's Avatar
Ahh...Rob gets it. There is one core with multiple rows.
Old Mar 21, 2011 | 12:31 PM
panos's Avatar
Also double check your timing,wrong timing can cause overheating.
Old Mar 21, 2011 | 04:00 PM
64Rocket's Avatar
Not enough advance timing.
rebuilt engine with too tight piston to cyl wall clearance.
water flow to slow.
water pump impeller wore down. (I've seen the stamp steel impeller brake off or lose fins)
spring in lower hose rust away, hose collapse.
Gene
Alex72cutty
Apr 21, 2015 10:30 AM
59Olds98
Aug 14, 2013 09:38 AM
g77rvd
May 13, 2011 11:29 AM
JONESY
Jan 11, 2005 09:19 AM
Bill
Feb 11, 2004 04:29 PM
