Another Cutlass
Old Aug 14, 2010 | 12:57 PM
CMN2GTU's Avatar
Another Cutlass
Guess I have been lurking around here long enough now that I should go ahead and post something.
Something.
This is my second '69, the first one having been snatched by the devil herself.
Link to my little photo journal effort in the signature zone down there...
Old Aug 14, 2010 | 01:07 PM
Welcome. Inner fender wells look good, mine are rotted out. So, fairly solid to start with.
Old Aug 14, 2010 | 01:17 PM
CMN2GTU's Avatar
Thanks.
After recently having a long block dropped in, I was going to jump right on the fenders, because the current body color makes me a little nauseous, but instead I started working on cleaning out the rear window channel after finding tell tale little pimples in the paint under the stainless.
Old Aug 15, 2010 | 10:41 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO, the problem with corrosion in the rear window channel is a common one.
Old Aug 15, 2010 | 11:44 AM
Welcome
Welcome aboard
We love 69's
Old Aug 18, 2010 | 09:08 AM
CMN2GTU's Avatar
Thanks one and all for the greets.
I too love 69's though I do admire the 68 front ends.
This one is not quite as clean as my first Cutlass (buildsheet folded up in the ashtray, abandoned by a bodyshop guy with an affinity for cheap white powders) but this one has more of what I wanted than the first one so....trade offs y'know I love em..
Though I could do with out the blood clot red-brown paint scheme.
Plans for this one are to follow the K.I.S.S. rule as much as possible.
Some minor (and reversible) changes are going to take place to bring the car current, as well as the obvious cleanup projects, but otherwise pretty much what you see is what you get.
As mentioned the old girl recently got a fresh 350 longblock (kept the core for a rebuild: F4 block and #5 heads).
I opted for the 350 because:
a.) that is what it had, and
2.)I don't race much so I just need the reliability
...plus I didn't want to have to hunt up and install a GPM fuel gauge to go with a 455.
@Oldsguy: yep this is the second time I have encountered cancer in that location on a GM car.
The first time was on my first car, a neglected '73 chevelle that I learned what not to do with.
Fortunately this rot has not made its way through yet, so I am counting myself lucky at this point.
I plan to do all I can to bulletproof this highly corrosion-prone area.
Right now I have the trim off and everything rough-cleaned and masked off.
I got the necessary POR15 products on order, so as soon as they arrive I will add more pictures of the progress.
My theory is that if I zinc phosphate and paint-seal the channel, all moisture will run down the gutters along each side of the trunk weatherstripping as intended.
One of the things that attracted me to this car was its lack of blingy-ness.
I am not fond of alot of shiny chrome, especially as window accent, so I am most likely going to have the trim powdercoated semigloss or satin black.
Going to have the clips P-coated as well, in hopes they won't decay.
Purists, please cut me some slack here...this car will never be sold so I am just making slight (and again, reversible) alterations.
The interior is to remain stock (including the AM radio), just planning to get the old buckets rebuilt. And a steering wheel that doesn't show 30% of its steel core.
Also I paused the other day to replace my crack-checkered and milky-toned tail light lenses for a better set.
Old Aug 18, 2010 | 09:25 AM
citcapp's Avatar
Talking Welcome to CO
Looks like a good project, gotta agree the existing color has got to go. Keep us posted with picture updates as you make progress.
Old Aug 18, 2010 | 09:49 AM
69oldsguy's Avatar
Very nice. I too am partial to the '69. Looks like you have a very nice project car there. Welcome to the site. Lots of good people and great cars here, but if you've been lurking, you already know that.
Old Aug 18, 2010 | 09:33 PM
Olds luvr's Avatar
Grown Azz Kid
Welcome aboard....
Old Aug 18, 2010 | 10:41 PM
64Rocket's Avatar
Nice project. Should be a nice looking car when done. Welcome aboard.
What part of Calif. are you from?
Gene
Old Aug 19, 2010 | 07:31 PM
CMN2GTU's Avatar
Gene
Just past the smallest pyramid, head south till you see the sphinx then bear due west till you spot the rock spray painted B.F.E.
It may be buried in a dune.
.....or El Cajon/La Mesa area, if you prefer
coldwar
Feb 20, 2014 01:09 AM
we jeep inn
Aug 19, 2010 05:46 AM
IDAS 69
Jul 10, 2009 07:31 PM
mikeb
Nov 11, 2008 04:38 PM
