Just bought a 1969 old 98. Help…
Old Sep 13, 2025 | 05:36 PM
big_smith's Avatar
1969 olds 98 2 dr convertible.
i have questions:
-is there a 4 wheel brake disc kit or diy method (front disk at least)
-do all 455 rocket performance parts bolt on to the 1969 olds 98 455 rockets? Headers, distributer, intake, gaskets, etc
-where can I get weather stripping and suspension parts?
-is there a good website for parts and performance and maintenance?
-I want aftermarket wheels, What’s the bolt pattern and hub specs? do 16 to 18 inch wheels fit?
-any headers that fit without modifications to the steering box? Like short headers
Please help. I want to make this a nice cruiser. I want to at least make it drivable. Maybe some performance if available. And 4 wheel disk brakes.
Good websites, diy, kits, info, and more.
i know it’s not a “enthusiasts car” so not much aftermarket. Anything helps.
Old Sep 13, 2025 | 05:48 PM
Buy this used paperback 1969 OEM GM Oldsmobile Chassis Service Manual (CSM). There may be others (used). Comes w/ color wiring diagram. It's the bible for your car.
https://www.ebay.com/itm/405238973905
Old Sep 13, 2025 | 05:55 PM
big_smith's Avatar
no one took this info and posted it online for free yet?
Old Sep 13, 2025 | 06:31 PM
You can find a .pdf of the 1969 Oldsmobile Factory Assembly Manual (FAM) aka the Product Information Manual (PIM) here:
https://autohistorypreservationsocie...M-PG-1-278.pdf
Old Sep 13, 2025 | 07:03 PM
Tell ya what. You buy one, scan it, and post it somewhere on line so others can get it for free.
Old Sep 13, 2025 | 07:14 PM
Be certain to scan the wiring diagrams in high resolution color so when you post the CSM they’re crispy.
Old Sep 14, 2025 | 02:31 AM
Tri-Carb's Avatar
For seals: Steel Rubber
Due to the lack of proper aftermarket parts, repair your existing braking system. If you do not currently have factory front disc brakes, advertise and search for factory donor parts. Leave the rear brakes as drum. I would leave the entire system as drum.
Get an appropriate tune up of your existing system. Forget headers. It is a big heavy car. It will never be a rocket ship in the performance arena.
Your wheels are 5 on 5. I would leave those as they are to maximize the distance between the tread and the rim.
Try your local parts suppliers for Moog brand suspension parts. Steer away from overseas made kits. Try www.rockauto.com for an overview of parts. Look to www.rareparts.com for rare parts.
Old Sep 14, 2025 | 05:13 AM
Bfg's Avatar
Bfg
There goes another 98 to be woken from a slumber sleep to wake up to a nightmare
big_smith
Sep 14, 2025 06:59 PM
69olds98
Oct 1, 2024 09:07 AM
MagicMan
Sep 10, 2021 05:58 AM
bobbysc
Feb 8, 2014 12:20 PM
gazza454
Jun 16, 2013 02:09 AM
