67 convertible. cutlass
Old Feb 13, 2020 | 02:37 PM
midiowa's Avatar
greetings all. ive been lurking thru all internet sites until I found this site. looks like the one to be on.. ok, so I have 67 conv cutlass that had a 330 that started out as a refresh and ended with needing complete rebuild. sooo my sons father in law has a 455 that was a recent rebuild 5yrs sitting on pallet in garage all kinds of motor work ,etc. says 500hp. picking it up cheap .(family Thing). I believe all brackets back on no problem, need bigger radiator? and the big question is the tranny? th350?th400? 700r4?
Old Feb 13, 2020 | 03:24 PM
Welcome to the site. I prefer the T350 or T400 as I don't care about the over drive. A T350 can be built to handle the power while the T400 is a bit more stout.
Old Feb 13, 2020 | 05:13 PM
OLDSter Ralph's Avatar
Welcome. The TH400 would be the best for strength behind a 455. Where in "midIowa" are you ?
Old Feb 13, 2020 | 07:48 PM
midiowa's Avatar
just south des moines. hard time finding that th400 olds tranny.
Old Feb 14, 2020 | 10:45 AM
Good looking Cutlass.
Old Feb 14, 2020 | 02:07 PM
X2, looks like a nice solid body.
Old Feb 14, 2020 | 02:15 PM
CRUZN 66's Avatar
Olds Fever
Welcome to the group... TH400 would be my choice as well... Sharp looking Cutlass...
Old Feb 14, 2020 | 03:47 PM
danktx's Avatar
My 67' CS Conv just recently got a 455 and I have a 700r4 behind mine. I like it.
Old Feb 14, 2020 | 04:18 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
A TH350 can be built to handle it So can a 200-4R. But...
A TH400 is stronger from the get-go. Knowing what the internals look like Id go TH400 with a GV overdrive. Or a 5 or 6 speed stick.
TH400 pros... just beefer. Cons more parasitic loss...but at 500 hp who cares.
At that HP/Torque level, I strongly consider chassis upgrades to include the cooling system, motor mounts, braking system, boxed rear lower control arms with sway bar, upgrade front sway bar, rear-end and a driveshaft/ujoint upgrade as well as some kind of frame "tieing"
You will need other mods such as shifter mods, ebrake front cable relocation, speedo calibration(verify the driven gear on the new trans if you do a trans swap), Trans cross-member relo or upgrade. Not sure if the ST300 2 speeds cross-member works with a TH400 by simply relocating it on the frame, but a 442 came with all of this so it should be straight forward.
The 455 torque will make short work of that 8.2" rear end and flex the body good enough to pop open the passenger door on hard acceleration with a good hook of the rear tires.
TCI makes a great Street n Strip semi-auto valve body TH400. Their converters are second to nun.
As you can see all systems must be considered with a single upgrade. A rebuilt 330 looks attractive now.
Let the MAWs commence.
https://www.jegs.com/p/TCI/TCI-Stree...46476/10002/-1
https://www.jegs.com/p/TCI/TCI-Stree...47568/10002/-1
Old Feb 16, 2020 | 05:40 AM
midiowa's Avatar
Heres motor picked up today. 396021f, e heads. Said ran hard pulled out car 4 yrs ago been in garage. Tear apart or go with it?
Old Feb 16, 2020 | 05:42 AM
midiowa's Avatar
its going in
Old Feb 16, 2020 | 06:00 PM
KOOL! You will enjoy it. Get the timing curve and fuel curve dialed in...super tune it for optimum performance. Ask if you need assistance there.
Old Feb 16, 2020 | 08:06 PM
midiowa's Avatar
Thanks guys!! looking forward to building this!!
Old Feb 23, 2020 | 08:12 PM
midiowa's Avatar
what motor mounts did you go with?
Old Feb 24, 2020 | 04:44 AM
danktx's Avatar
I used the small block mounts. There's a sticky on here about what mounts fit.
Number is 2261
Old Feb 25, 2020 | 08:13 AM
Weezer's Avatar
Jeff
Hey, let's see a better shot of that interior. I spy black with brown inserts, which I'm sure is not an original look, but I dig it.
Old Feb 26, 2020 | 06:18 PM
Bler57's Avatar
Big block will always keep a smile on your face!, that’s why we drive them!!
Old Feb 29, 2020 | 01:14 AM
69CSHC's Avatar
Welcome aboard, and nice ride.
Nice, sounds like fun.
If you had a base 330 with stock setup, I would say bigger radiator for sure as well as a 7 blade fan and definitely a shroud.
With regards to trans, if stock units than there is no other option but a TH400 imho. 500 HP and likely 500 lb ft screams for it. In the end factory knew best when we are talking stock. Big block engine should be paired with a big block trans. A built big block even more so.
PS as has been mentioned with regards to the rear-end on your Cutlass, if its a 8.2 proceed with caution. I hurt one on the street with regular day to day driving. Albeit with a heavy foot from time to time in my younger days. The rear broke with a 250 HP 330...
Old Feb 29, 2020 | 06:31 PM
midiowa's Avatar
Old Feb 29, 2020 | 06:35 PM
midiowa's Avatar
yep, going with olds th400 found. finally, radiator 4 core and new shroud? thinking the same on a rear end upgrade. . what do you guys think for rear end?
vickycar
Sep 16, 2018 07:27 PM
Roger60
Oct 14, 2017 07:48 AM
Roger60
Nov 28, 2015 09:06 AM
reghenderson
Jun 10, 2014 03:40 PM
jr's67
Sep 3, 2010 04:50 PM
