1970 olds 442 w-30 lights flikering..
The place where you should introduce yourself. Do not ask technical questions here, use the site forum sections.
Nov 10, 2019 | 12:53 PM
COBRA2000
Oct 2019
SAN ANTONIO TX
1970 olds 442-w30 lights are flikering at any rpm...i suspect voltage regulator.... Any thought's???
COBRA2000
Find More Posts by COBRA2000
Nov 10, 2019 | 01:37 PM
joe_padavano
Mar 2007
Northern VA
Quote:
Originally Posted by
COBRA2000
Check and clean the terminals at the threaded junction post on the horn relay. I've had this problem before and cleaning those terminals helped a lot.
joe_padavano
Find More Posts by joe_padavano
Nov 10, 2019 | 01:49 PM
COBRA2000
Oct 2019
SAN ANTONIO TX
joe_padavano
check and clean the terminals at the threaded junction post on the horn relay. I've had this problem before and cleaning those terminals helped a lot.
cool.. I will give it a try...
COBRA2000
Nov 10, 2019 | 02:51 PM
COBRA2000
Oct 2019
SAN ANTONIO TX
Well I can't find the voltage regulator....Is this one of those located in the alternator??
COBRA2000
Nov 10, 2019 | 03:19 PM
oldcutlass
Oct 2009
Poteau, Ok
If the alternator plug terminals are "l l" then its externally regulated. If it has "- -" terminals then its internally regulated.
oldcutlass
Find More Posts by oldcutlass
Nov 10, 2019 | 03:21 PM
joe_padavano
Mar 2007
Northern VA
oldcutlass
All 1970 442s came with internally regulated alternators.
joe_padavano
Nov 10, 2019 | 03:37 PM
COBRA2000
Oct 2019
SAN ANTONIO TX
joe_padavano
Thank you!!
COBRA2000
Nov 11, 2019 | 06:03 PM
COBRA2000
Oct 2019
SAN ANTONIO TX
Problem solved.. It was the alternator... Put a new one in and working like a CHAMP!!!
COBRA2000
Nov 11, 2019 | 06:07 PM
70W-32
Mar 2013
St. Clair, MI
COBRA2000
Is the new one open face like the factory original?, or just a generic rebuild.
70W-32
Find More Posts by 70W-32
Nov 11, 2019 | 06:11 PM
COBRA2000
Oct 2019
SAN ANTONIO TX
70W-32
generic build... DURALAST...lifetime warranty... could not find a AC/DELCO here locally...
COBRA2000
Nov 11, 2019 | 07:03 PM
oldcutlass
Oct 2009
Poteau, Ok
I hope you kept the old one and didn't turn it in as a core.
oldcutlass
Nov 11, 2019 | 07:05 PM
COBRA2000
Oct 2019
SAN ANTONIO TX
oldcutlass
I did....why??
COBRA2000
Nov 11, 2019 | 07:13 PM
oldcutlass
Oct 2009
Poteau, Ok
Because when people are looking for/at W cars, they like them to have all the original parts. All parts removed from your car are valuable.
oldcutlass
Nov 11, 2019 | 07:17 PM
COBRA2000
Oct 2019
SAN ANTONIO TX
oldcutlass
gotcha….
COBRA2000
Lights Flickering
johnspd22
03:36 PM
Flickering Lights on a 72
brown7373
01:09 PM
all lights gone...
CrazedCountryRebel
Dec 24, 2012
05:37 PM
lights pulse
rmoths
06:03 AM
1972 442 head lights dim
1972 X code 442
01:49 PM
Newbie in Nebraska
12:04 PM
