1970 olds 442 w-30 lights flikering..
Old Nov 10, 2019 | 12:53 PM
COBRA2000's Avatar
1970 olds 442-w30 lights are flikering at any rpm...i suspect voltage regulator.... Any thought's???
Old Nov 10, 2019 | 01:37 PM
Check and clean the terminals at the threaded junction post on the horn relay. I've had this problem before and cleaning those terminals helped a lot.
Old Nov 10, 2019 | 01:49 PM
COBRA2000's Avatar
check and clean the terminals at the threaded junction post on the horn relay. I've had this problem before and cleaning those terminals helped a lot.
cool.. I will give it a try...
Old Nov 10, 2019 | 02:51 PM
COBRA2000's Avatar
Well I can't find the voltage regulator....Is this one of those located in the alternator??
Old Nov 10, 2019 | 03:19 PM
If the alternator plug terminals are "l l" then its externally regulated. If it has "- -" terminals then its internally regulated.
Old Nov 10, 2019 | 03:21 PM
All 1970 442s came with internally regulated alternators.
Old Nov 10, 2019 | 03:37 PM
COBRA2000's Avatar
Thank you!!
Old Nov 11, 2019 | 06:03 PM
COBRA2000's Avatar
Problem solved.. It was the alternator... Put a new one in and working like a CHAMP!!!
Old Nov 11, 2019 | 06:07 PM
70W-32's Avatar
Is the new one open face like the factory original?, or just a generic rebuild.
Old Nov 11, 2019 | 06:11 PM
COBRA2000's Avatar
generic build... DURALAST...lifetime warranty... could not find a AC/DELCO here locally...
Old Nov 11, 2019 | 07:03 PM
I hope you kept the old one and didn't turn it in as a core.
Old Nov 11, 2019 | 07:05 PM
COBRA2000's Avatar
I did....why??
Old Nov 11, 2019 | 07:13 PM
Because when people are looking for/at W cars, they like them to have all the original parts. All parts removed from your car are valuable.
Old Nov 11, 2019 | 07:17 PM
COBRA2000's Avatar
gotcha….
johnspd22
Apr 7, 2018 03:36 PM
brown7373
Jun 4, 2015 01:09 PM
CrazedCountryRebel
Dec 24, 2012 05:37 PM
rmoths
Jun 16, 2012 06:03 AM
1972 X code 442
Jun 12, 2008 01:49 PM
