The Great OBD Challenge!
Old Jan 9, 2019 | 09:25 AM
Cliffhanger's Avatar
Hello all. I'm hoping for a little help here. I have a 1995 Olds Silhouette. This is the year they were transitioning OBD ports from OBD1 to OBD2. I am aware of the paper clip trick on OBD1 ports to read trouble codes by shorting the "A" and "B" terminals, but mine is different. I have no lead going to the "B" terminal. My OBD plug only has three wires going to it, and one of them is not to the "B" terminal. I have been to every auto parts store and two mechanics now...nobody can figure out how to read the trouble codes with this specific plug. Anybody have a similar experience? Is there any way for me to pull the codes without paying a dealership $100 to do it?
Thank you all in advance.
Cliff
Old Jan 9, 2019 | 09:34 AM
Old Jan 9, 2019 | 10:13 AM
Your OBD 1.5 system does not have the diagnostic terminal that lets you jumper the terminals. The only way to read this is with a scan tool that is specifically compatible with OBD 1.5.
http://www.imhdd.ms11.net/OLDS/obd.html
Old Jan 9, 2019 | 10:30 AM
This should be the three wires in your ALDL connector.
Old Jan 9, 2019 | 03:37 PM
classicmuscle442's Avatar
Have a '95 Firebird and have had no luck at all trying to retrieve codes. Has the OBD 2 connector and has OBD 1 wiring.
Old Jan 9, 2019 | 04:38 PM
Chevy and related cars (like the F-body) used the 16-pin OBD2 connector for these transition cars. Olds and Buick used the 12-pin OBD1 connector. There are a limited number of scan tools that can read them. Most vendors, especially those selling the low-end scan tools, don't bother to support this limited market.
Battenrunner
Oct 19, 2019 10:07 PM
defiant1
Jan 3, 2018 05:18 PM
Octania
Jan 3, 2015 06:09 PM
tgilligan
Mar 3, 2014 06:59 PM
