Reception of Firebird Transams powered SBO's
Are Firebird powered SBO owners well received on the board?
Just curious.... I am a fan of the Olds small block having learned by default with 79 Firebird TA .403.
I have a project where I am swapping engines temporarily to refresh my 403 as I restore my Firebird (low miles orig. 33k miles & numbers matching)
I have been blessed with getting a .330 HC for temporary use. Excited as it will be a lot of fun.... I am figuring I will have > double the HP than my stock .403
. I hope I dont get spoiled.
Thanks to LemOldsNut user for the 330
. I hope I dont get spoiled. Thanks to LemOldsNut user for the 330
Some of us Olds owners LIKE the 2nd gen Trans Ams, even if they are Olds powered.
THIS! I wish I still had my '79 and '82 T/A's! They were BAD-A$$, LOL! They turned all the girls' heads
Absolutely, we love them. My wife would also not be against me getting one either. I am finally assembling my 424ci 403 stroker, just a 330 crank offset ground. You can get much better parts now than even a few years ago. Consider Cutlassefi's 4" stroker billet crank with aftermarket rods and a piston with a 1mm ring pack. If that is too many dollars, get as light a piston as possible with a modern thin ring pack and aftermarket rods. Mine has Venolia custom pistons with a .043" top ring, 1.5mm second ring and weigh 550 grams have a .927 sbc pin on Scat sbc 6" rods. Also don't use the stock 4A heads unless you are willing to spend a lot of dollars porting them, the exhaust side is horrible on them. A roller cam and better heads go a long way.
Hey, we're car guys and gals. Why wouldn't we appreciate iconic cars?
You can't get much more iconic than the T/A, especially for people of our general age group.
Good luck with your fun project. Keep us posted as it progresses (with lots of pictures).
