newbe
Old Apr 12, 2016 | 08:14 AM
froggys86's Avatar
Talking newbe
Have a '86 cutlass supreme with a floor shifter and was wondering if the plunger for shifter is bolted down or just in there so I can replace it because tip broke off so shift **** won't fit (factory ****)properly, any help is appreciated. .....
Old Apr 12, 2016 | 05:16 PM
1970cs's Avatar
Lansing built
Pictures would help a lot! If memory serves that mine broke above the horse shoe clip.
Pat
Old Apr 12, 2016 | 05:58 PM
Ka Pow! Pat that's exactly right. Same from 78-88 console models.
Old Apr 12, 2016 | 08:46 PM
froggys86's Avatar
Yes mine snapped right above horseshoe clip also,can I just remove the plunger or is it somehow fastened on at the base of the shifter. ...
Old Apr 13, 2016 | 03:07 AM
1970cs's Avatar
Lansing built
Again, If memory serves, pull the horseshoe clip, remove broken pieces. Replace the plunger and new T-handle shove down on handle till the grove shows in the clip opening and replace the clip.
Do you have a new handle? If not here is a link. FYI I have a NOS burgundy one floating around here somewhere.
http://www.gbodyparts.com/product_in...oducts_id=1893
Pat
Old Apr 13, 2016 | 10:37 AM
froggys86's Avatar
Pat
I have the original shifter it's jus that the inside where it holds it in place is broken on the inside,I just have the plunger sticking like a sore thumb....so to replace plunger just pull up on it correct, also is there a way to repair the inside of shifter. ....once again thanks for all the help.
Old Apr 13, 2016 | 03:18 PM
CRUZN 66's Avatar
Olds Fever
If you should need to purchase another shifter, I have a few spares available... I also stock NOS handles and spare parts for the handle, However, no spare parts for the shifter itself...
Old Apr 13, 2016 | 06:01 PM
1970cs's Avatar
Lansing built
Your taking me back 15 years plus. Any way you can post a picture of the area you are speaking of?
Pat
Old Apr 14, 2016 | 08:42 AM
CRUZN 66's Avatar
Olds Fever
Here's a photo of the shift lever parts:
I believe he is looking for item #25... Shift lever rod extension...
Old Apr 14, 2016 | 09:22 AM
froggys86's Avatar
Would like to thank everyone for their help,greatly appreciate it,can't semester to figure how to upload pics thru my phone,but, a big thanks to all.
KustomPontiac
Mar 17, 2010 06:28 PM
526 turbo
Oct 15, 2009 11:13 AM
Burning_Rubber
Mar 30, 2009 02:38 PM
Bobsw32
Feb 27, 2009 06:47 AM
marshall-no
May 15, 2008 09:24 AM
