winter storage question
Hey everyone
I purchased a nice convertible 67 Cutlass Supreme.Winter is upon us here in Tn.
And a garage this winter is out of the question,period.What to do is my question.Here are my options.I have a asphalt driveway.Or a bed of sand where I took down my swimming pool.Will the sand possibly keep more moisture out?
Or hold the water in causing more moisture? Or will the asphalt option fair better? Should I cover and park closer to the house where it blocks some morning dew? I feel just terrible that this piece of history might be ruined because I have no garage.There is no body rust and the interior is almost perfect. Thanks for any Pro input you may have.
Check all the fluids especially your antifreeze, air up the tires to max pressure on sidewall, throw in some stabil on top of a full tank of fuel, stuff a rag in the exhaust pipe to keep the critters out, and cover her up.
LOL OK IDK what winter might bring in TN
I would store it like Oldcutlass said on the tar not sand w a good cover, take out the battery and keep it charged up. Some poeple use dryer sheets everywhere as a rodent deterrent. Some poeple hang dessicants in the interior and trunk to absorb moisture
portable garages are cheap too, even in a PG I would do all the above at a minimum
Your TN winter was like ours here in TX...
Park on the pavement and use a good cover. Secure it well, too.
Oldcutlass had a good list for you.
The key is to not park on soil and keep wet tree crap off of it.
Make sure the door and body drain holes are clear.
Try to get it out and drive it on your nicer days. That helps dry it out and keeps it exercised.
My Ford stays out all the time on the driveway and also gets driven during all the non-hot months. Surprising, there is still no rustout from anywhere.
Steve
ps - What part TN? I am in Northeast.
