Wheatherstripe OLDSMOBILE DYNAMIC 88 [1966]
Hi there.
I'm from Polish. I have a 1966 OLDSMOBILE DYNAMIC 88 4 door [no post]. I can not find anywhere on the door seals on the back. Where can I buy them? On the Fusick.com not have such in the catalog. Do OLDSMOBILE from another model will fit? If so, from what model? Here 'image of the product from the catalog. The second question. Are those chrome bars will fit into my car / model? Also send a photo.
My English is bad. Sorry. I hope you understood me. Thank you for your help.
You may want to try Steele Rubber products. Or maybe you need to buy universal type stripping and make your own. Look also at Restoration Specialties. I dont think any other car will be exactly the same as doors are not the same.
I would think (if all else fails) you could buy the 98 holiday sedan seals and modify them to fit. The doors are basically similar, but the 98 doors are a few inches longer. You would likely have to start from each end working toward the middle, then cut out the excess and glue the cut ends together. Just a thought.
dynamicraiderrich
Dec 13, 2011 05:12 PM
