What do these #'s mean ?
Old Apr 11, 2012 | 08:49 AM
Eldomiwok's Avatar
129 398704yrh*d8y Gmy 411961 *?di 125
Old Apr 11, 2012 | 10:05 AM
66luvr's Avatar
Checking account number?
Old Apr 11, 2012 | 10:15 AM
frankr442's Avatar
Give us a clue. Where do they come from?
Old Apr 11, 2012 | 10:31 AM
Bluevista's Avatar
Registered
It's either an ICBM launch code or the cheat code for a 70's Pong video game.
Old Apr 11, 2012 | 10:47 AM
Eddie Hansen's Avatar
going by your other post
those are the exhaust manifold numbers
'66 4 398704 RH; 330. Standard issue manifold.
'68 - '73 5 398704 RH; X-over. 350. Delta 88.
?? 1 411961 LH; No X-over. Straight down. 307, 350 gas, 350 diesel.
seems they are for a 68-73 350 in a full size car? this is just a guess 1 is the right hand side one is the left hand side, the date code and plant probably make up the balance of the numbers.
Old Apr 11, 2012 | 10:51 AM
don't take it the wrong way
BTW don't take the guys ribbing the wrong way, they may not have read your other post, and they are not mind readers, the best way to get info would be state the part you found the number, and if possible a picture, they are a great bunch of guys, but there are thousands of posts to read, and to get the best answer you need to give the best info.... hang in there bud, you will get a set of manifolds for your 455, but these are not them... they are for a small block car, while they will bolt up, they will do more harm then good.. get the manifolds I mentioned or go with headers...
Old Apr 11, 2012 | 11:01 AM
Eldomiwok's Avatar
Ya u guys have been way helpful tryin to figure what's interchangeable on 350. That's still n car.I have iPad an iPhone trying to post pics thanks again
Old Apr 11, 2012 | 11:11 AM
eldo, ok just a few basics that will save you some time.
generally speaking you can use everything ( accessories) from the 350 on the 455 except the intake manifolds and exhaust manifolds, you will need to look at the water pump to make sure it is the same thickness so the pulleys etc line up. even the oil pan will be the same.
Old Apr 11, 2012 | 11:16 AM
Eldomiwok's Avatar
?starter ? Radiator nor cal gold country don't get hotter than 110 here
Old Apr 11, 2012 | 11:34 AM
yes, most probably the rad will work if it is in good shape etc yes the flywheel, starter, tranny, torque converter, will all work. bear in mind the 455 will have lots more torque, so if it is a turbo 350 tranny it may not last if your beating on it.
Old Apr 11, 2012 | 12:21 PM
Eldomiwok's Avatar
Ya I'm anticipating my original trans to go out an build it strong. Don't want to move cross member e brake or linkage. Thanks for the info
tm70olds
Oct 15, 2014 06:18 AM
young olds
Aug 16, 2013 10:28 AM
oakwith
Jul 9, 2012 06:07 PM
coltsneckbob
Drivetrain/Differentials
Sep 8, 2009 05:52 PM
GoldOlds
May 22, 2007 09:19 AM
