turbo 400 speedometer plug
Old Aug 7, 2014 | 12:29 PM
irkennedy's Avatar
When I bought my cutlass the 400 trans had a plug where the speedometer cable goes so I do not how fast I'm going. Has anyone dealt with this before? Is there a way to remove it?
Old Aug 7, 2014 | 01:56 PM
don71's Avatar
same but different
If it has a plug in it, chances are the transmission came from a big car, like an Olds 98. Those cars had the speedo driven off the front wheel. Probably a long tail transmission as well.
Any chance you have a pic? Just in case something else is going on here. Might not hurt to give us the total length of this trans, for comparison.
I'm not sure what direction to point you too. You might be out of luck.
Old Aug 8, 2014 | 07:39 AM
hookem horns's Avatar
In the meantime, get the Speed Box app for your phone - simple, accurate and FREE. I got it to check the speedo accuracy of the Cutlass and the boat. If you have a tach in the car, use the app to check your speed at various RPM's once in top gear (2500 = 60mph, etc).
Old Aug 8, 2014 | 09:04 AM
More specifically, the 1965-70 Delta 88 and Ninety Eight drove the speedo cable from the left front wheel, not the trans. Your transmission is from one of those cars. Some of these transmissions came with a plug in the hole, some simply didn't have the hole machined. If yours has the plug, it is possible to remove it and install the speedo gear holder so you can run a cable. You'll also need to pull the tailhousing and install a drive gear on the output shaft. If your case isn't machined for the hole, you are S.O.L.
Old Aug 8, 2014 | 09:31 AM
JohnnyBs68S's Avatar
Anyone know why Olds did that? Seems to be a more complicated way of getting road speed to the dashboard (the cable would have to flex U/D/L/R w/ the spindle, no?). I always thought this was wierd on my buddy's dad's '70 98, when he told me the speedo pickup was on the front wheel, I didn't believe him until he punched it and spun the rear tires and the speedo hardly moved. Seems that the only benefit would be that you could switch tire size or rear gear ratios without having to re-gear the speedo cable, yet these cars weren't exactly ripe candidates for doing that.
Old Aug 8, 2014 | 07:06 PM
irkennedy's Avatar
So if it is not drilled for it then I would need a new transmission? Is there any other way to determine mph without a new trans?
Old Aug 10, 2014 | 11:38 AM
Well, a new case at a minimum.
From Post # 3 above:
Old Aug 10, 2014 | 12:14 PM
4speed455's Avatar
I was told if the tranny doesn't have the provision for the speedo, the drive shaft of the tranny will not be machined to accept the speedo drive gear.
Old Aug 10, 2014 | 12:17 PM
The long tail output shafts are the same. The drive gear just wasn't pressed into place.
1k442
Sep 9, 2012 01:02 PM
80_cutlass
Mar 17, 2011 06:03 PM
Liegekiller
15
Jun 27, 2009 07:58 PM
Liegekiller
May 30, 2009 05:31 PM
