Transmission advice.
The place where you should introduce yourself. Do not ask technical questions here, use the site forum sections.
Oct 30, 2016 | 02:45 AM
dewwhy
Sep 2014
I put a chevy 700 transmission in my 1964 cutlass f85 does any one know what I need for a transmission mount and can I use the 64 cross member ?
dewwhy
Find More Posts by dewwhy
Oct 30, 2016 | 03:47 AM
oldcutlass
Oct 2009
Poteau, Ok
You need to use the mount for the 700 your stock xmember. It will need to be moved and new holes drilled in the frame to mount it in its new position.
oldcutlass
Find More Posts by oldcutlass
Advice on 71 Cutlass Transmission change/swap
VI Cutty
09:35 AM
Need advice Please.
rtdoff04
06:39 PM
Buying advice for for n00b seeking Hurst Olds...
mismith356
02:42 AM
Please help...advice needed Fast
Want-A-Vert
07:06 PM
advice on Buying a 442
c1run1
05:18 AM
What model is this ols?
02:22 AM
