trans advice
trans advice
Hello,
I have a trans question…I purchased a 72 cutlass with a 1978 350 motor and 350 trans, I then purchased a original 1972 350 rocket and 350 trans. My question is… the trans output shaft that connects to the driveshaft is smaller in diameter than the 78. Both transmissions work good, so should I change the yoke or switch the trans over to the 72?
