throttle return spring placement
Old July 18th, 2011 | 09:05 PM
mv64cutlass's Avatar
Hey all, newbie here from Northern Cal. I have owned a 64 cutlass for about a year now and finally registered on the site. I've gone through alot of the forum and got some really good ideas and help...love the site. I'm in the process putting the throttle linkage back together after some cleanup on the top of the motor and can't remember where the return spring hooks to on both ends. I usually take lots of pics but must have got in a hurry and didn't. I know I have all the parts, can anyone help me out with some info or a pic of the linkage of a 330 with a 4bbl? Its still all original as far as I know. Thanks for any help.
Old July 19th, 2011 | 06:10 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO. Good answer to your question is forth-coming soon, I am sure. Good luck.
Old July 19th, 2011 | 08:51 AM
jrzybob442's Avatar
45 yrs of Olds Nuttiness
We have the 1965 Factory Assemby Manual which shows the carb spring setups which will be the same for 1964.
All you need to do is go to www.wildaboutcars.com and register, then follow the link below and download the section or the page you need.
http://wildaboutcarsonline.com/membe..._ASM_Sec_6.pdf
Old July 19th, 2011 | 08:17 PM
Thanks for the welcome Dan, and thank you for the great info jrzybob. Wildaboutcars looks like a great resource and I already registered. The drawing of the 65 throttle linkage was a great help (came back to memory after looking at it...doh!) It isn't exactly like the 64 setup but really close and I was able to figure it out from there, Thanks again!!
Old July 20th, 2011 | 06:05 AM
Welcome aboard
I've seen a few people use 2 just for safety
defiant1
February 16th, 2014 06:00 PM
defiant1
May 12th, 2011 10:32 AM
4-Speed
April 2nd, 2010 02:27 PM
Flye
August 30th, 2009 05:18 AM
68conv455
May 20th, 2008 02:03 PM
Quick Reply: throttle return spring placement
