terry 57
Old Nov 29, 2010 | 12:20 PM
terry 57's Avatar
terry 57
i want to install disc brake converion on my 57 olds and wondering if the power brake unit works or is there a better way as the brake unit is under the floor thanks
Old Nov 29, 2010 | 12:34 PM
citcapp's Avatar
Welcome to CO
Terry,
In order to install disc breaks on your 57 you will have to convert to a firewall mounted after market power booster and dual master cylinder, this requires removing the air box on the engine fire wall and installing a blank plate. Then you will have to install a hanging brake pedal assembly from a 70's model donor car. This will require fabrication. I did this conversion using the scarebird brake kit http://www.scarebird.com/. on my 57 Olds.
The below floor system cannot accept a dual master cylinder. Good luck, if I can be of any help pm me
Pat
Old Nov 29, 2010 | 12:55 PM
Welcome
Welcome aboard
I see Pat's got cha going in the right direction.
Old Dec 1, 2010 | 10:34 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO.
ozoneblue
Nov 1, 2007 06:40 AM
