South central WI - restoring a 1969 Oldsmobile 98
Old Jun 25, 2023 | 06:09 PM
nickwisconsin's Avatar
Thought I would introduce myself. I inherited this car from my Dad. It was his father's car. Started doing a restoration. The frame itself is a bit rough cosmetically and there is a bit of rust on the hidden bits, but the body is pretty good. If I had a lift, the space, and the ability I would have done a frame off, but it is not really needed. I am learning a lot here. I just joined the OCA. Any other olds enthusiasts in WI feel free to drop me a line, especially if you are working on a project too.
Old Jun 25, 2023 | 06:20 PM
Welcome. Looking forward to pictures of what was your Dad's car. Some other members from Wisconsin on here.
Old Jun 25, 2023 | 06:27 PM
Thanks. I started a build thread. I am fairly good with my hands and mechanically inclined, but have not worked much on cars. Mostly bikes, motorcycles, gunsmithing. I started this as a frame on project, but in retrospect, a frame off would have made the underside clean up a lot easier. I don't have a lift and my space is not heated, so it is somewhat limiting.
I am replacing brake lines, brakes, and will likely have some suspension work. The radiator leaks but it runs just fine. I am more or less figuring it out as I go. I am bit concerned with screwing something up, but that is half the challenge I guess. Case in point, I sandblasted the gas tank. The inside was fine, but the outside was rust. I have heard from several people since that you should not sandblast a gas tank since they are so thin that it will lead to pinholes. I had to solder all of them up. Lesson learned, but I am not a believe in rust encapsulation.
I keep hoping I will find a retired guy who is an olds guru and is bored and looking for a project to help on. LOL
Old Jun 25, 2023 | 07:30 PM
Welcome to the site, I will have to check out your projects thread.
Old Jun 26, 2023 | 05:20 AM
Welcome again!
Here's a link to your build thread.
https://classicoldsmobile.com/forums...3/#post1507217
Old Jun 26, 2023 | 06:47 AM
67OAI's Avatar
Old(s)GuysRule
Welcome aboard! Sounds like a great project. Post a picture or two here when you can.
Old Jun 26, 2023 | 07:37 AM
Thanks! There is a link to my project thread in the post above yours.
Old Jun 26, 2023 | 11:37 AM
otto72's Avatar
Welcome-
I like the car, it will be nice to get it back on the road. Lots of folks on the site willing to share ideas and methods.
Keith
Old Jun 26, 2023 | 01:48 PM
68glorydays's Avatar
I am from central wis and welcome to the site. Iola car show coming up soon July 6th – 8th sometime you get lucky
but it is getting harder to find Oldsmobile parts in the swap meet.
Old Jun 26, 2023 | 06:13 PM
olds70supreme's Avatar
SW Wisconsin here.
MagicMan
Sep 10, 2021 05:58 AM
bobbysc
Feb 8, 2014 12:20 PM
oldsmobilty
Sep 27, 2012 04:26 PM
sonofolds
Jun 17, 2010 04:26 AM
