Seat Back Lock Button & Escutcheon Assembly Removal
I need help regarding removing the lock button & escutcheon assembly from the bucket seat back of my 1969 Cutlass. I have to repaint my seat backs. I did this twelve years ago when I purchased my Cutlass; however, I broke both assemblies during removal. I have tried everything from screw drivers to trim removal tools. The service manual is of no help, as it just states remove the escutcheon assembly. I am hoping that I do not have to repaint the seat backs while still on the seat.
Any advice will be most appreciated. I'm greatful I found this website.
Seat Back Escutcheon
Thank you so mcuh for the reply. How much pressure should I be using? Should I be pushing in from the sides or should I try to wedge the screw driver down into where the escutcheon assembly is into the seatback?
Your Cutlass is beautiful. I thought I had alot of work with mine; however, after seeing your detailed pictorial, I had it easy!
I purchased two different sizes of plastic putty knives yesterday from my local hardware store. I will attempt the assembly removal again tonight.
One other question I forgot to ask: does it matter if the seatback is in the upright or folded down position when I am trying to remove the assembly?
Thank you.
Thank you.
Thank you.
Thank you.
synoptic12
October 2nd, 2018 11:36 AM
