Ring end Gap
Old Dec 20, 2015 | 07:40 AM
Justbill's Avatar
Ring end Gap
New to the site just bought a 71 Cutlass with a 69 455 motor that needs some work. I'm Trying to find out the proper end gap for the rings on a 69 455 that's bored 030 over. Any info is appreciated.
Justbill
Old Dec 20, 2015 | 12:00 PM
Justbill
Welcome. For stock-style cast rings, factory spec is 0.013"-0.023" for the two compression rings and 0.015"-.0.55" for the oil ring.
Old Dec 23, 2015 | 08:17 AM
bobus8's Avatar
As a general rule of thumb, you can use .005 for every inch of bore and that will put you in the ballpark for ring end gap. The Hypereutetectic pistons generally call for .0065 per inch of bore for the top ring only.
If you think these are excessive, check the factory gaps on what came out of your engine.
BTW I'm talking only about the compression rings. I've never had a problem with gap on oil rings.
Old Dec 23, 2015 | 08:37 AM
Uh, the factory gap specs I posted above match up exactly with your 0.005/inch of bore.
4.125 x 0.005 = 0.021" gap. Factory spec is 0.013-0.023.
Old Dec 24, 2015 | 07:50 AM
bobus8's Avatar
Joe. Where in N. Virginia are you located. I'm in W. Springfield.
Old Dec 24, 2015 | 08:32 AM
Lovettsville in Loudoun Co.
wabasto
Dec 23, 2015 01:09 PM
orange442
Jul 9, 2015 04:32 PM
jims2000lt
Oct 10, 2013 07:56 AM
dman0712
Apr 13, 2010 06:38 PM
The_Jeremiah
Dec 7, 2007 08:06 PM
