Replacement Key??????????
Is there any way to get replacement ignition key.
Data Tag Decoder Results Year 1972 Make Oldsmobile Model Cutlass Supreme Hardtop Coupe V-8 Engine (J57) Assembly DateFirst week of OctoberAssembly PlantFisher Body Sequence 01551Lower Color Nordic Blue Upper Color/Conv TopWhite Vinyl Convertible TopInterior OptionBlue Vinyl Bucket Accessory Codes
Not from the body cowl tag. Heck, if that were the case, anyone who could lift the hood, and hoods did not have inside latch releases until the late '60s or early '70s, could simply lift the hood, copy down the info on the tag, go have a key made, and steal the car.
If you don't have an ignition key, you'll have to call a locksmith and ask how to get a replacement. I'm assuming that, without an ignition key, the car can't be started, let alone driven. Perhaps a locksmith will have to come to wherever the car is to make the key.
Another possibility is to have a car dealer's repair shop put in a new ignition switch or lock cylinder. I had a similar problem with a much newer vehicle, an '02 Dodge Dakota, a few years ago. One day the ignition switch would not turn at all with the key inserted. It was like I had the wrong key. The AAA guy couldn't get it to turn, either, so he towed it to a Dodge dealer where they disassembled the ignition switch and put in new lock pins. It cost me $102, $2 for the lock pins and $100 for the labor.
In short, I'm sure there's a way to get a new ignition key, but it's likely to involve either getting a locksmith to the car or having the car towed to a locksmith or dealer.
I assume this is for the 72 Cutlass below. If so, the dealer does not have the codes. You will have to pull the switch take it to a lock smith to get a key made. I have never done it. I do know you have to pull the steering wheel, the turn signal switch and a locking plate. Maybe someone else can give you the exact procedure.
QUOTE=nolabigdawg;722189]Is there any way to get replacement ignition key.
Data Tag Decoder Results Year 1972 Make Oldsmobile Model Cutlass Supreme Hardtop Coupe V-8 Engine (J57) Assembly DateFirst week of OctoberAssembly PlantFisher Body Sequence 01551Lower Color Nordic Blue Upper Color/Conv TopWhite Vinyl Convertible TopInterior OptionBlue Vinyl Bucket Accessory Codes[/QUOTE]
Read up in the Service Manual, spent $22 (including shipping) for a full set of pins and a new cylinder on eBay, spent half an hour pulling the cylinder (surprisingly easy), and was done.
As for the OP's problem: Pull a door cylinder and read the code off of it.
Joe P. can punch you a key from your code, as can most genuine locksmiths.
My point in suggesting taking the car to a dealer was not to imply that the dealer would have the key codes. There are no more Oldsmobile dealers, we certainly don't know which dealer sold this car, and even there were still Oldsmobile dealers, it would be unlikely that any of them would have key codes for cars sold 40+ years ago.
My point was that car dealers should be able to address any problem a car might have. If an ignition key is lost and they don't have a way to make a new one, they can disassemble the steering column and put in a new lock cylinder or whatever is needed. Certainly, in the history of automobiles, people have lost car keys, so dealers should know how to handle this. One possibility for the OP is to call a nearby GM dealer's service department and ask.
Taking the door lock cylinder off to have a key made from it is a good idea, too, but that's a bit of a bother. If you're going to go through that much trouble, why not just have the locksmith out to your house or wherever the car is and have him make a key on site using either the door lock or the ignition key slot. Certainly locksmiths make house calls as I've seen my share of locksmith company vans around town over the years. They have to be mobile if they're going to service locks on building doors and so forth.
I pulled a door lock out of one of my 67's, got the number code and gave it to Joe Padavano. in about a week i had a key that worked perfect!!! He has some kind of old key machine that makes the key when you punch in the code. PM him maybe he can help you.
Steve
Steve
The key code is on the lock cylinder. On a '72, the ignition key and the door lock key should be the same-the square one with a "C" on it. The trunk/glove box/console door key is the round one that should have a "D" on it. If you pull a door lock and take it to a locksmith, they should be able to read the code on the cylinder and cut you a new key to that code. Just hope that no one has changed out the door lock or ignition cylinders during the life of the car!
Randy C.
Randy C.
On a 72 the ignition key should be the same as the door key, but it is not difficult to pull the ignition lock to read the code. You need to remove the steering wheel, lock plate, and turn signal switch first. This website has detailed photos. Note that that website talks about repairing the common loose tilt column, but the process to get the key out is the same. Just stop at that point and don't disassemble any further.
The tech industry has finally come up with a term for the answer you'll get: "No longer supported."
86ChebbyWagon307
Jul 5, 2011 07:09 PM
JMW803
May 13, 2010 04:43 PM
