Removing Opera Windows
Ok, guys, how do you remove the opera window and trim on a 73 supreme.
I have removed the vinyl top and the interior sail panel. I have removed the interior glass clips and do not know where to go from here.
Thanks in advance for any help.
It's been a couple years since I pulled a set, but if you have the interior clips removed you may be down to just the adhesive. Just a big bead of black sticky windshield sealant. Either cut it with piano wire or let it sit in the hot sun for a while and try pressing it out with your hand. John
