Question about solid main 350
Old Mar 15, 2016 | 05:31 PM
1slowbird's Avatar
Sorry for the noobish question but, I hear solid main windowed mains, I'm looking at 395558 block out of a 69 cutlass and all the pictures I've seen don't look any different than the ones in my 403. I can't seem to find a picture of what solid mains look like. Does anyone have a pic of a solid main 350? Are the mains as solid as the diesel block?
Old Mar 15, 2016 | 07:27 PM
Octania's Avatar
At long last!
The 403 with main webs like the 395558-2 block!
Old Mar 15, 2016 | 08:04 PM
1slowbird's Avatar
Originally Posted by Octania
At long last!
Sarcasm?
I found a 350 block from a 69 cutlass with #5 heads and I'm wondering if it's worth it. I'm asking because when I look online the pics I find don't look any different.
403
350 (395558-2)
Old Mar 15, 2016 | 10:27 PM
don71's Avatar
same but different
Look closely between the crank shaft main bearing journals and the bottom of the bores. Those big holes there..those are the windows. This is a 403.
Old Mar 16, 2016 | 05:50 AM
Every single Olds V8 block cast prior to the 1977 model year had solid mains. Every single Olds V8 gas engine block cast from 1977-1990 model years had windowed mains (and larger 1/2" head bolts) to reduce weight. Diesel blocks were all solid web.
Old Mar 16, 2016 | 05:58 AM
1slowbird's Avatar
Wow, now I really feel like a noob.
I never knew that's what they meant. I thought it was the area to the left and right of the main caps.
Thanks.
Do you think I should pick up that 350? Guy is asking $100?
Old Mar 16, 2016 | 08:01 AM
Octania's Avatar
I thing a good 350 core should be worth $100 sure
There is a very long and involved back story to the 403 webs thing, so don't feel too bad. I am the one who decided it was a Myth after offering a reward for many months for even so much as proof that they exist. Maybe search "SMW 403" or "Solid Main Web 403" for more info.
I wanted to chime in but not make you feel too bad and even leave open the possibility that one had finally appeared.
Welcome!
If the 350 has heads, all the better.
after Joe's summary in post #5, as usual with Joe's post, there's not much to add. He nails it.
Old Mar 17, 2016 | 04:41 PM
1slowbird's Avatar
No problem Octania, I knew the legend of the SMW 403, and even heard about the reward. I was just looking at the wrong area of the block. I just assumed everything I was seeing was a windowed block. Anyways, Thanks for the info.
Old Nov 4, 2018 | 04:58 PM
FrankDMayo's Avatar
Question 350 block 395558 - 2 F4
I picked up am Olds 350 engine today. The number on the machine plate is 32M22783 casting F4 on the back behind the flywheel says its a 72 model I assume with the higher nickle metal content. It has the solid main webs. My engine heads are number 7a casting 409147 and engine casting 395558 - 2. The crank has the number 383654. What is the advantage of solid main webs? Being new to Olds engines do the numbers sound like they are original parts ?The motor was reported to have been rebuilt recently with about 5000 miles use after the rebuild. it does appear to have been as the cylinders honing still appears fresh and the valve springs are the heavy springs. I'm looking for about 280-300 hp for my intended application. Thanks Frank.
Old Nov 4, 2018 | 05:07 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Yes, the 7a heads are 72 cylinder heads. Does the crank have a big N on it? The solid main gas block is much stronger than the windowed main block, more than people will ever need. What pistons? Stock replacement, big dish cast pistons are no good, too low of compression. Just get the Mahle 10cc dish pistons and a mild cam, easy 300 hp with dual exhaust.
Old Nov 4, 2018 | 05:10 PM
Fpcopo's Avatar
Windowed mains are no good for anything above moderate power levels. Mild street motors are fine with these windowed blocks I have heard. Still, if you have a choice, get the solid block.
Old Nov 4, 2018 | 05:15 PM
FrankDMayo's Avatar
yes it has the Large "N" I don't find my crank number listed but its 3 8 3654 although a 3 93654 is listed as a 350 crank with no N not as a nodular crank. Mine does have the "N" on the first lobe of the crank so I suspect it's a possible 455 crank if its possible to fit in the 350. I'm thinking who ever rebuilt this engine may have hop up the horse power already. Wish I knew what Olds car it came out of originally it'd ne great to put it back in there.
Old Nov 4, 2018 | 05:19 PM
FrankDMayo's Avatar
I gave the guy 300 dollars for it he was asking 500 but he took 300. I'm hoping that was a good price
Old Nov 4, 2018 | 05:20 PM
What pistons?
Old Nov 4, 2018 | 05:23 PM
FrankDMayo's Avatar
I don't know I haven't pulled the heads off to see. I can see a number on the cam but I didn't write it down but I can go look.. Maybe tomorrow I'll pull the heads and look at the pistons and see what I can find there.
Old Nov 4, 2018 | 07:23 PM
Good plan, let us know the number on the cam and a picture is best for the pistons along with the stamped numbers.
Old Nov 5, 2018 | 05:06 AM
FrankDMayo's Avatar
I have re checked my Crank and the number 10 times and I swear the second number is an 8.. but I still can't find it in the engine parts listings. so I'm gonna say it is a 9 but looks like an 8. So my crank is 393654 with a CAPITAL "N" on the first counter weight at the front main bearing which from what i've read should not have the "N" marking it as a nodular metal crank. The piston rods I don't see any number on them so far. The piston itself I assume the markings are on top because I'm not finding any from below turning the engine by hand
Old Nov 5, 2018 | 05:30 AM
The crank is more than good enough for your build plans, a nodular crank. The pistons should have numbers on top, if replacements. I am just making sure the 24cc factory dish pistons weren't reused or the even worse 24cc cast replacement oversize pistons weren't used in the build. They have an even shorter compression height meaning less than 8 to 1 compression. The flat top forged pistons will put compression over 10 to 1, not good either. The only passable pistons that should stay are the no longer made 6cc or 14cc cast replacement pistons or the Speedpro LF2321 6cc dish forged pistons. Cutlassefi brought 10cc dish forged Mahle pistons with ultra modern 1mm ring packs and are much lighter as well. They will give low to mid 9 to 1 compression for your motor, perfect. He can also pick a cam to work with your goals.
Old Nov 5, 2018 | 06:24 AM
FrankDMayo's Avatar
The crank also has 010 writtt on the counter weight
the crank has 010 written on the counter weight looks like soapstone. From underneath the pistons look flat no doubt someone rebuilt this engine.
Old Nov 5, 2018 | 06:27 AM
FrankDMayo's Avatar
Intake
The intake is an elberbrock performer 350 olds intake
Old Nov 5, 2018 | 06:34 AM
FrankDMayo's Avatar
End caps number
Would any numbers on the connecting rods end cap help I’d the CR
Old Nov 5, 2018 | 06:42 AM
FrankDMayo's Avatar
Connecting rods
Few photos
A few internal photos
Old Nov 5, 2018 | 07:40 AM
FrankDMayo's Avatar
Pistons
The pistons are .030 oversized dated 12 05 82 Christmas gift I guess : number 332AP look like dish circular in the middle recessed inward.
Old Nov 5, 2018 | 08:56 AM
Sealed Power 332 AP are the big dish pistons described below.
Old Nov 5, 2018 | 09:43 AM
FrankDMayo's Avatar
I found the pistons
SLP-L2320F30 - Speed-Pro Forged Pistons
at Summit Racing the price isn't bad. I also found the molly rings as well.
Looks like a little change is in order.
Old Nov 5, 2018 | 12:25 PM
Go back and carefully read post #18 above.
Old Nov 6, 2018 | 04:00 PM
https://www.summitracing.com/parts/slp-l2321f30
These will work better but they cost less than Mahle pistons for a reason, heavier and thick rings which cost power, fuel efficiency and have more drag.
Octania
Sep 25, 2014 05:23 PM
69sAndrew
May 27, 2011 09:01 PM
falconsfan
Jun 1, 2007 08:05 PM
falconsfan
May 31, 2007 04:33 AM
Craftsman442
Feb 19, 2007 07:43 PM
