Question about intake manifold gasket seals on a olds 350
Old Sep 19, 2018 | 10:44 AM
  #41
kev.e's Avatar
Is there anyway by looking at the engine or gasket in the car without taking off the intake manifold to see if it has the turkey tray or if it has regular gaskets?
Old Sep 19, 2018 | 03:17 PM
  #42
RetroRanger's Avatar
72 Olds CS
if you look at the mating surface of the intake and the head you can some of the gasket sticking out, if your not sure take a pic an post it.
Old Sep 19, 2018 | 04:22 PM
  #43
kev.e's Avatar
I could see it its steel how's that tell me if it has a turkey tray or nor?Or are only turkey tray's steel?
Old Sep 20, 2018 | 07:43 AM
  #44
kev.e's Avatar
So no way to tell if it has a turkey tray by looking at it?
Old Sep 20, 2018 | 09:04 AM
  #45
classicmuscle442's Avatar
Should be able tell in the heat riser area where intake attaches to heads
Old Sep 20, 2018 | 09:14 AM
  #46
kev.e's Avatar
Thank,s Chris
Old Sep 20, 2018 | 09:16 AM
  #47
Dockolds's Avatar
I always used the sealant (liquid gasket) in lieu of the rubber gasket on the intakes. I watched the rubber gaskets just squirt itself out of place of an assembled engine while still on the stand with and without silicone. So I do the same thing that I used to do on my sprint car engines...liquid gasket. 11 years on my 455 with the W30 intake and not one problem yet.
Old Sep 20, 2018 | 11:07 AM
  #48
kev.e's Avatar
Thank's for the info Dockolds,so do you use liquid gasket for the whole job on the gaskets ,in front and rear where the seals go and around the water ports?
Old Sep 20, 2018 | 11:24 AM
  #49
Dockolds's Avatar
Good amount front and back and a skim coat around water jackets. just have to careful putting manifold back on so you don't get the goobie every where but where you want it. If on an engine stand if you want to detail or tool out the excess. Spray it down with soapy water after installed and use an 1/8" rubber setting block (From my Commercial Glass Days) or putty knife and scrape off excess for a finished look before it sets up. wherever its wet it wont stick to other surfaces as you scrape of excess. Then let it set up for 24 hours and your good to go and off to the races.
www.somernitescruise.com
Old Sep 20, 2018 | 12:42 PM
  #50
kev.e's Avatar
Ok thank's for the information Dockolds!
Old Sep 23, 2018 | 04:07 PM
  #51
kev.e's Avatar
I just used a typical metal turkey tray from fel pro. and the right stuff silicone on the end seals. i have no other data points
Im looking for "the right stuff silicone" you guys mentioned but cant find nothing that says silicone,i did find "the right stuff" made by permetex is that it?
Old Sep 23, 2018 | 04:22 PM
  #52
Actually, the Permatex Ultra Black (or color of your choice) is newer and a better seal.
Old Sep 23, 2018 | 04:30 PM
  #53
Piece of advice with the turkey tray, dry fit and make sure the bosses go into the bolt holes. You may need to bend the tray here and there so it lays flat by itself.
Old Sep 23, 2018 | 05:31 PM
  #54
kev.e's Avatar
Can someone please tell me if the permatex ultra black ,can i use that for the whole job,gaskets, end seals and skim coat around water jackets?
Old Sep 26, 2018 | 10:22 AM
  #55
kev.e's Avatar
Question? I looked up intake manifold valley pan gaskets and Edelbrock directions say i should use Fel-pro valley pan gasket #MS96027 ,i looked up at advance auto and O'reilly valley pan gasket for 1972 350 olds and it shows #MS96009 ,i typed in the one Edelbrock recommends and it says will not fit the car.Is that because the intake manifold was changed and now that one wont fit?I just wanna make sure i get the rite part. which one is the one i should get for a 72 350 olds with an Edelbrock intake?
Old Sep 26, 2018 | 10:57 AM
  #56
The only difference between the two is the size of the opening for the exhaust crossover. The '009 gasket has the small hole to match up with the 1972-earlier heads. The '027 gasket has the larger hole for 1973-up heads. Get the gasket that matches your cylinder heads.
Old Sep 26, 2018 | 11:10 AM
  #57
kev.e's Avatar
Thank's ,i have # 6 heads as far as i know no work has ever been done on them.And i've been reading the reviews on the MS96027 and there are people that say they fit better and that the 009 dont fit that good with the edelbrock intake.
Old Jun 8, 2019 | 11:51 AM
  #58
Ikesgotav8's Avatar
Kev.e, did how did your intake turnout? Did you use the rubber gaskets, or just use black RTV sealant? My gasket set came with to black plastic pieces I do not recognize, and I think I will not be using as I have no reference in the service manual. Thanks for your time.
Oldracerjones
May 10, 2014 12:47 PM
dallasite21
Dec 6, 2011 03:00 PM
rkk69olds
May 3, 2011 05:00 PM
nukesec1
Sep 28, 2009 05:16 AM
