Question
Old May 3, 2014 | 02:17 PM
Oldsmobile-F85's Avatar
Question
Why does my 1970 oldsmobile F85 have 4 lines coming off of the gas tank ?
Old May 3, 2014 | 04:49 PM
don71's Avatar
same but different
Welcome.
Its part of a system that includes a stand pipe and charcoal canister for recovering fuel vapors.
Its a good idea not to modify these things. If you have any cracked hoses it is a good idea to replace them.
Here is one link that talks a little about the stand pipe. Don't let the title throw you. You can search for more on the charcoal canister as well. This will at least give you an idea if you don't have a factory manual....its all in there. If you have an old car, you need one.
https://classicoldsmobile.com/forums...t-working.html
Old May 3, 2014 | 04:57 PM
So it can go four times as fast.
Welcome to ClassicOlds.
Old May 3, 2014 | 04:58 PM
reply
Could I cap those lines off and use one line for fuel to engine driven pump and is the other line a bypass line from the fuel pump back to the fuel tank ?
Just got my 1970 F85 and nothings hooked up right
Old May 3, 2014 | 05:04 PM
don71's Avatar
same but different
I wouldn't do that. If its just temporary maybe yes if only checking other stuff.
Old May 3, 2014 | 05:06 PM
don71's Avatar
same but different
Tell us what your doing. Like whats going on with the old car?
Old May 3, 2014 | 05:17 PM
Sure you could. You just have to be sure you've got a way for air to get into the tank.
The original setup served this purpose well, so the best thing to do would be to fix whatever's broken.
Old May 3, 2014 | 05:21 PM
Really appreciate the responses
And so basically the 2 extra hoses are basically vents? That could be tied together and put a small filter on ?
Old May 3, 2014 | 06:45 PM
I suppose.
Why not read the section on the evaporative emission controls in the Chassis Service Manual?
That way, you can make an informed choice.
yeahbuddy
Dec 19, 2011 08:40 PM
