push rod probs
push rod probs
hi everybody I have a 87 salon with 85 front end a 68 350 in it. block numbers 395558 2 and head numbs 397742 5. I ordered pushrods 8.234" and too short. the old is 8.375 or 8 3/8" where can I get these and cheap. the prices I see are 100 something or am I wrong with this or maybe the liftrs are collaspt
Maybe your engine has had some work done to it. Heads shaved,deck etc. This plays along with worn parts.
A typical lifter has compensation for .060. Doing the math your pushrods have a difference of 0.141. Thats more than twice the length a typical lifter can compensate for.
You need a checking push rod. Its adjustable. You measure it. You need one, two actually.
This is one of the last things you measure for when building a new(old) engine.
A hundred dollars is not out of the ball park for new push rods.
push rods
oh the lifters are tapping. the ones that are on there are all different sizes like their worn out so I thought I need new ones. my friend says it might be collaps lifters. but I still cant find the 8.3/8" sizes cheap any way.some are off 1/16th to 1/8" thanks for the help
