pale rider
pale rider
Well I finally downloaded pics of the hot rod , successfully I hope . So far I discovered I had a blown head gasket I replaced them in the process I found out it had one " j " head and one "g" head on it. I replaced both heads with the G heads off of a 71 block . Now I have no fire going to the middle two cylinders on the passenger side . And also every time I put it in drive it stalls out and gas shoots out the carb . The engine is a 455 with a holley 650 and a stage one cam . Basically I am cleaning someone else's mess up .
This weekend I plan on doing the compression test again and yes I just discussed today with my brother about the floats ,so this weekend I will be doing a lil carb work . I changed wires and cap today it ran a little better and I drove it 15 miles or so through town and it ran ok .
holidaysedan
December 21st, 2010 03:38 PM
