pale rider
Old Jun 26, 2013 | 09:49 PM
oldhearse's Avatar
Red face pale rider
Well I finally downloaded pics of the hot rod , successfully I hope . So far I discovered I had a blown head gasket I replaced them in the process I found out it had one " j " head and one "g" head on it. I replaced both heads with the G heads off of a 71 block . Now I have no fire going to the middle two cylinders on the passenger side . And also every time I put it in drive it stalls out and gas shoots out the carb . The engine is a 455 with a holley 650 and a stage one cam . Basically I am cleaning someone else's mess up .
Old Jun 26, 2013 | 10:24 PM
Grace Stinespring-Welch's Avatar
olds
sounds like your timing is off,along bad wires or cap.
Old Jun 27, 2013 | 01:29 PM
citcapp's Avatar
That's one big ride. Could a used that back in high school
Old Jun 27, 2013 | 01:45 PM
don71's Avatar
same but different
I was gonna say that too, Welcome to the site. You might check your float level and do a compression check on those two. Tune up all ready mentioned... Sounds like you got a couple of problems going on.
Old Jun 27, 2013 | 01:50 PM
Kibby70's Avatar
pale rider
I have trouble with pictures, where do I go to view yours?
Old Jun 27, 2013 | 01:55 PM
Kibby70's Avatar
I found them....
Old Jun 27, 2013 | 08:57 PM
oldhearse's Avatar
This weekend I plan on doing the compression test again and yes I just discussed today with my brother about the floats ,so this weekend I will be doing a lil carb work . I changed wires and cap today it ran a little better and I drove it 15 miles or so through town and it ran ok .
Old Jun 27, 2013 | 09:08 PM
Nice car, bet it's a great conversation piece.
RonFX
Body work
Jan 17, 2015 09:07 AM
RonFX
Body work
Sep 20, 2014 11:12 AM
RonFX
Brakes/Hydraulic Systems
Jul 16, 2014 04:22 PM
RonFX
Paint
Jun 15, 2014 08:19 AM
holidaysedan
Dec 21, 2010 03:38 PM
