Oldsmobile cuttlass Coolant leak.
Hello,
I recently got an oldsmobile cutlass.
I found out that this coolant is leaking behind the timing cover.
Do I have to replace the gasket behind this or is there more problems behind?
The water pump bolts to the front of that cover, which encloses the back of the water pump (and covers the timing chain). If coolant is leaking from behind that cover, you've got a leak somewhere behind the water pump that is getting past that cover into the area where the timing chain resides (coolant is also likely getting into the oil pan too). I'd start by removing the water pump and see if you can find the source of the leak.
The only place leaking from what I can see is there.
Are you sure it can't leak there?
The most likely source of coolant in that area is the weep hole on the bottom of the water pump. From there it would run down and drip off the front edge of the timing cover as Joe described.
