oil hat leaking
Old Jun 22, 2012 | 10:58 AM
oldstata's Avatar
Justin
oil hat leaking
took the old girl out for the first drive since I bought it i beleive the oil cap is leaking. I know i read some where in here about a fix just cant seem to find anything now
Old Jun 22, 2012 | 11:19 AM
Oil cap leaking? You might have too much crankcase pressure. Have you checked or changed your PCV valve lately?
Old Jun 22, 2012 | 11:22 AM
x2
Old Jun 22, 2012 | 11:52 AM
oldstata's Avatar
Justin
it has a crome style cap that hooks to the air cleaner and no have not changed it I guess i could un hook it and see if it stops ?
Old Jun 22, 2012 | 12:24 PM
Take out the PCV and shake it. If it rattles it's ok. If you hear nothing it's plugged. These are really inexpensive and quick fix parts.
Plugged up PCV can lead to oil leaks elsewhere too.
Can you post a pic of your engine compartment? Is this for your 65?
Old Jun 22, 2012 | 12:31 PM
Huh? That is not your pcv! It may be a vent, your pcv should run to the carburator or intake port.
Old Jun 22, 2012 | 12:36 PM
That confused me too. Also why Iasked for a pic.
Old Jun 22, 2012 | 12:40 PM
oldstata's Avatar
Justin
i will have to look when i get home
Old Jun 22, 2012 | 12:45 PM
oldstata's Avatar
Justin
maybe i am thinking of newer cars thought pcv was on the line from valve covers
Old Jun 22, 2012 | 01:15 PM
oldstata's Avatar
Justin
Yes it's my 65 I will post some pics tonight
Thanks for all your help sorry I realize this is pretty simple stuff just never worked on stuff this old before
Old Jun 22, 2012 | 02:18 PM
Pcv is on the valve cover, usually the passenger side, on the drivers side there is a vent, or breather, possibly a tube to the air filter housing.
Old Jun 22, 2012 | 02:40 PM
oldstata's Avatar
Justin
That's what I thought drivers side valve cover has nothing going to it pass side has a crime vent with a tub to the air cleaner so I guess no PVC ? But I will check in a few just about to leave work from what I can remember only hoses off of intake is to the booster and the carb is to the distribitor
Old Jun 22, 2012 | 03:26 PM
Let us know!
Old Jun 22, 2012 | 03:58 PM
Should be something like this. I guess I can see why you call the filler tube cap a HAT BTW, you should check the filler cap to see if there's a rubber seal inside. It may have deteriorated with age?
The PCV you can get from Rock Auto for less than 2 bucks
http://www.rockauto.com/catalog/moreinfo.php?pk=50405
If the cap is no good, you can get a new gasket or install after market cap.
http://www.oreillyauto.com/site/c/de...21breather+cap
Old Jun 22, 2012 | 04:50 PM
oldstata's Avatar
Justin
Okay I have the 330 with number 2 heads alts in the center and were you PVC is is a air vent with a tube to air cleaner I don't see a rubber seal on the hat / oil cap it's a after market Crome one further more drivers side valve cover has a small filter in the hole were some thing should go on a later year so dont think it's a pressure issue maybe bad rings ?
Old Jun 22, 2012 | 05:25 PM
oldstata's Avatar
Justin
With it idling and pulling on the throttle a little smoke comes out of oil tube looks grey to me proble blue just cantt tell I am guessing bad rings😰not a lot but not really sure I do front end work not engine work
Old Jun 22, 2012 | 07:49 PM
oldstata's Avatar
Justin
Old Jun 22, 2012 | 07:55 PM
oldstata's Avatar
Justin
sorry the pics look better in my album the engine area needs lots of attenion to get rid of the wire mad house that the last guy left me with wires going every witch way.
so I went to a local car show and seen my very first olds 442 at one been to a ton and have never seen one .the guy had a 1967 with a 400 so I asked him if I could check out his pvc system he thought i was pretty nuts! so I am going to copy his set up he ran a tube off of the carb to the drivers side valve cover and installed his pvc there. and on the pass side just had a breather cap nothing going to his air cleaner looked way clean
Old Jun 22, 2012 | 09:40 PM
Sorry, it's really hard to see anything clearly in your pic. Try resizing it before you post again. Try to get the detail of the setup you installed.
Old Jun 22, 2012 | 09:46 PM
oldstata's Avatar
Justin
Sorry still pretty new to posting pics there are a few in my album that I took off the crome filter thing but who ever owned it before I am guessing took the PVC valve off and put that on instead they put crome covers on and both have holes in them were the oe ones only pass side does for PVC ? I am totally guess tho I will try and take better pics thanks so much for you time and input
Old Jun 22, 2012 | 09:57 PM
No worries. You have to start somewhere. I looked at your album but there's not a lot of detail that I can see to comment on. I assume that silver vent in the second engine pic is hooked up to nothing? Does it go to the valve cover?
GAOldsman's Avatar
"Car"mudgeon
Put a breather on the driver's side valve cover and a PCV (Positive Crankcase Vent) on the passenger's side
Old Jun 22, 2012 | 09:59 PM
oldstata's Avatar
Justin
Yes one is top view and the other is bottom view yes that's in pass side valve cover with a tube that goes to the air cleaner
Old Jun 22, 2012 | 10:01 PM
oldstata's Avatar
Justin
That's why a thought it was the PVC lol
Old Jun 22, 2012 | 10:06 PM
oldstata's Avatar
Justin
Sorry first pic is hole in valve cover sec is bottom of that breather filter that hooks to the air cleaner
Old Jun 23, 2012 | 11:04 AM
Either side will work, just make sure your PCV is hooked to manifold vaccum. Put a vent on the other.
Old Jun 23, 2012 | 09:42 PM
oldstata's Avatar
Justin
So installed PVC to day and took it for a 20 mile cruze it drove great no oil coming from the hat/ oil cap drove great just need to run the power wire for the choke
Old Jun 23, 2012 | 09:43 PM
oldstata's Avatar
Justin
Thanks for the help guys
Old Jun 24, 2012 | 06:51 AM
Glad all worked out!
70Post
Mar 4, 2015 12:09 PM
defiant1
Aug 26, 2011 09:45 AM
442 Guatemala
Jan 21, 2010 09:13 AM
Dan Wirth
Oct 18, 2009 07:27 PM
