Newb
Old January 3rd, 2018, 01:39 AM
1965Jetstar's Avatar
Newb
Picked up a very solid 65 jetstar 2d hard top bucket seat center console years ago. Been a very slow off and on project. Finally really started at it over the last few weeks. No experience with paint/body work. Trying to get it to primer so it's a respectable driver. Got the front bumper off today. Rechrome shop is suppose to call with a price quote tomorrow. Waiting on my new coil springs and shocks in the mail. Should be here any day. Checked the rear diff fluid level today and the plug started to cross thread going back in. It's always 2 steps forward 3 steps back with me and projects. Loving the forum and looking forward to learning.
1965Jetstar is offline
Old January 3rd, 2018, 02:25 AM
Welcome to the site, lets see it.
oldcutlass is online now
Old January 3rd, 2018, 06:44 AM
Welcome. Be sure you are sitting down when you get the quote for the chrome. I'm guessing about $700.
joe_padavano is offline
Old January 3rd, 2018, 09:02 AM
my2cents's Avatar
I'd be happy with that.... over here in Germany, they ask 1500 euros for one bumper...
my2cents is offline
Old January 3rd, 2018, 03:50 PM
Olds Fever
CRUZN 66's Avatar
Welcome to the group... Good luck with your project... Chrome work prices can very quite a bit... Depends on your requirements for quality... Double versus triple chrome plate etc... As well as the location of the chrome shop... The closer to your location with the best references is always a good thing...
CRUZN 66 is offline
Old January 3rd, 2018, 04:15 PM
thank you. She's pretty ugly right now but here ya go.
Old January 3rd, 2018, 06:45 PM
Oldsmaniac's Avatar
I don't think you mentioned it was a Jetstar I, which is a whole different beast and way more desirable than a plain Jetstar...very cool.
Oldsmaniac is offline
Old January 3rd, 2018, 07:17 PM
awesome! Great to know. Parts have been next to impossible to find. I grew up in the back seat of a 65 olds 98 and found this one in my searches for a 98. It was all the same dash etc as I remembered as a kid but much sportier. I honestly never even heard of the jetstar before buying this one. So am not very knowledgeable about it. Read about people poo pooing on the model. So that must have been just the jetstar model? I knew I couldn't go wrong when I saw the interior package and solid bones.
Old January 3rd, 2018, 07:27 PM
Oldsmaniac's Avatar
You have a 425 engine (providing it is original) with factory dual exhaust and a Turbo 400 trans. There are differences between the small block Jetstar such as differential, wheel bolt pattern and suspension parts. Always ask for parts for a Delta 88, Dynamic or Starfire when it comes to brake parts, engine parts suspension parts. Do not even mention the word Jetstar as you will get no part or wrong parts.
Old January 4th, 2018, 07:31 AM
Oldsmaniac's Avatar
FYI it also looks like wheel adaptors are on the front drums, this is not quite the way to go for aftermarket wheels. It is better to get the proper bolt pattern wheels.
Old January 4th, 2018, 08:45 AM
Olds built two different cars in the 1964-66 timeframe, both rather confusingly called "Jetfire". Both were versions of the B-body platform, which included the Eighty Eight family. The Ninety Eight is a C-body, but except for the longer wheelbase, it is nearly identical to the B-body mechanically. As you correctly remember, the B-body and C-body use the same dash and (except for grill details) are identical from the front seat forward.
On those two different Jetstars, there was the low-rent Jetstar 88 and the sporty Jetstar I. Yours is the latter. The J88 was a loss leader full size that used the smaller 330 engine, Jetaway automatic, brakes, and differential from the Cutlass line. People downplay the J88 due to it's low-rent station in life.
The Jetstar I was intended to be a slightly less expensive version of the Starfire. Engine, trans, suspension, and brakes are pretty much the same as those in the Starfire. Trim is slightly toned down. The Jetstar I is a pretty cool and unique Olds from that vintage.
As noted above, the Jetstar I is really just another version of the Eighty Eight line, so order parts for an Eighty Eight, since few will have ever heard of the Jetstar.
As for the wheel "adapters", they look more like spacers. In any case, your car uses a 5 x 5" wheel bolt circle and wants wheels with close to zero offset. Adapters or spacers are not a good choice, as most are cheaply made and have questionable strength. People often use them on cars like this to run "bling-y" wheels designed for a FWD car that have far too much positive offset.
Old January 4th, 2018, 11:36 AM
Thanks very much fellas. The 425 seems to be long gone and engine codes pulled as a 69 455 I believe. Do you know if the delta 88 front and rear bumpers are the same? Great information and really glad I joined the site.
Old January 4th, 2018, 11:56 AM
Yes they are. Unfortunately, these have the mounting brackets on the backside that trap dirt and salt, causing the bumper to rust out. Nice used ones will be difficult to find.
Old January 4th, 2018, 12:59 PM
yes. I can't get 2 of the bracket bolts off the back of the bumper. They just spin. Can't get the backside to grab to get the nuts off. Frustrating stuff.
Old January 4th, 2018, 01:11 PM
Unfortunately the bolts are supposed to have a square section, like a carriage bolt, that fits into the slot in the bracket to keep it from spinning. Once the bolt or bracket rusts, the bolt spins. This is what a cutting torch is for.
Old January 5th, 2018, 11:33 AM
got the quote from the chrome shop. $1,000-$1500 per bumper. Damn. How do people sell finished projects for $15-20k???
Old January 5th, 2018, 11:52 AM
They take it in the shorts. These cable shows are total BS as far as turning a profit. It is always much less expensive to buy a completed car than to build one.
That fact has not yet stopped me from acquiring more projects, however.
Old January 5th, 2018, 01:26 PM
Oldsmaniac's Avatar
That seems high to me, Ogden Chrome does mail order bumpers and I use Tri City, they are usually at Carlisle swap for drop off and pick up. The last one I had done 3 years ago was 500 bucks.
Old October 24th, 2018, 04:38 AM
Slow progress updated pics.
Old October 24th, 2018, 04:41 AM
Old October 24th, 2018, 05:29 AM
Looks like a pretty darn solid car! I love the 65 Jetstar 1! Very nice..
Greg Rogers is offline
Old October 24th, 2018, 05:19 PM
eric66's Avatar
Nice work .What color are you painting the car?
eric66 is offline
Old October 26th, 2018, 12:27 PM
Thanks much! This is the color I am going with for my first round learning the process. It’s taken forever to get to this point. Zero experience working with any of this stuff other than watching my dad a few times when I was young.
alonzofredrick
May 5th, 2015 05:53 AM
German442
November 1st, 2012 10:21 PM
Mike Allen
July 1st, 2011 09:11 AM
64 Madcow F-85
March 5th, 2010 01:08 AM
cutlassgal
August 12th, 2009 09:00 AM
Quick Reply: Newb
