New to the site
Old Mar 26, 2014 | 01:10 PM
88jetstar's Avatar
New to the site
Hello, My name is mike and I have had a profile here for a while yet i have never posted. Mainly do to lack of time with my car. She is a 1964 Olds Jetstar 88 hard top with what I think is a 330 (99% positive just need that confirmation). I have had her is 2002. I did some work on it for a couple years to clean it up and get it going. the interior was pretty much gone when i got it, motor had a bunch of sludge in it transmission hardly has any miles on it but leaks like a race horse. College and living in an apartment got in my way of doing more to it. I finally have a place for it to come live with me and i am picking it up friday. I have a set of bucket seats and a center console for it from a 65 starfire that i got recently that need to be redone. I was hoping to either make it faster or just get a whole different motor. I have a edlebrock performer olds 350 intake manifold on it and a demon 650 cfm carb on it. The heads need rebuilt or just out right changed however the exhaust manifolds are cracked right at the bolts and once they come off they will not bolt back up. any input on where i can find parts, stock, oem, performance would be great.
Thank you
pics
Old Mar 26, 2014 | 01:25 PM
Welcome, looks very solid.
Old Mar 26, 2014 | 01:27 PM
88jetstar's Avatar
Its a CA car, has been its whole life, there are some issues around the rear wheel wells on the body. something else i need to fix
Old Mar 27, 2014 | 08:18 AM
Nice looking car, and yes, the stock engine would have been a 330. Be aware that the 1964 330 motors have a lot of one-year-only parts like the heads, shaft-mounted rocker arms, water pump with driver-side inlet, balancer, timing tab, and accessory brackets.
Old Mar 27, 2014 | 08:44 AM
D. Yaros's Avatar
Looks like a great project with solid potential. Enjoy!
Old Mar 27, 2014 | 12:23 PM
88jetstar's Avatar
Thanks, how would identy the year the motor was made? Also can a 330 be made powerful? Or would an engine swap be a good idea? I am not married to the motor at all. A strong 455 would be nice however
Old Mar 27, 2014 | 01:33 PM
Unfortunately, you can't prove the year of your motor because 330 motors didn't get the VIN derivative stamp that included the model year - Olds didn't start using that until the 1968 model year. If your motor has the water pump with the driver's side inlet and shaft mounted rockers, it's either a 1964 motor or someone went to great lengths to put the 1964 parts on a later block.
As for the HP, the 330 is a good motor with a forged crank, but it's still a small motor in a heavy car (with the Junkaway, er Jetaway two speed trans). A different trans with a lower first gear (2.52:1 in the TH350 vs. 1.76:1 in the Jetaway) will make a huge difference in off-the-line acceleration. Of course, nothing will wake the car up like a big block, and a 425 or 455 is nearly a bolt-in.
Old Mar 27, 2014 | 03:09 PM
88jetstar's Avatar
I have been reading that the 64 jetstar has different mounts for the motor. Do you have any links to a how to or a motor swap thread showing how to fix this?
Also any links to where i could secure a 425 or 455. Summit and jegs seem to only have chevy crate motors and i really dont want to do that to my olds.
Old Mar 27, 2014 | 04:08 PM
The 64 J88 motor mounts are unique to that car and year. No one repros them so you must reuse your old ones or get them revulcanized by Steele Rubber if they are bad. Any 1964-1990 Olds motor bolts in with the factory 64 mounts.
Old Mar 27, 2014 | 11:01 PM
88jetstar's Avatar
Well thats good to know, now i just need to find a motor and trans. Thank you
Old Mar 28, 2014 | 04:36 AM
fbonanno's Avatar
Welcome. Looks nice. Thanks to Joe P, it looks like you have allot of options if you want to go with a different engine.
Old Mar 28, 2014 | 05:40 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO, very nice looking car. I agree with Joe, you should find a BBO for that car, 425 or 455 will fill the ticket.
Old Mar 28, 2014 | 06:31 AM
Keep in mind that if you elect to use a TH400 or 200-4R, the trans crossmember will need to be moved back, and since these transmissions were not available in the 64 cars, the frame rails are not drilled for this. You'll need to drill new holes. Also, the TH400 will require a custom shorter driveshaft with a larger front yoke.
Old Mar 28, 2014 | 05:25 PM
88jetstar's Avatar
Thanks for that infomation, i would like to get a 455 and a TH400 in the car eventually. I got the car to my place today some pics at the bottom, it barely fits. Good think i got it inside finally its supposed to rain pretty good tomorrow. My dad was kind enough to let me keep it at his place since 2002. Does anyone know where i can get the window seals and sweeps for the car?
Old Mar 29, 2014 | 09:57 AM
Steele Rubber, P/N 80-0790-57
Old Mar 29, 2014 | 10:01 AM
88jetstar's Avatar
You are awesome
Old Apr 1, 2014 | 07:32 PM
OLD SKL 69's Avatar
GM Enthusiast
Welcome to CO! Looks like a nice car, good luck with the project.
Old Apr 1, 2014 | 07:59 PM
Kyle's 77 Cutlass's Avatar
Nice ride, enjoy the site
Old Apr 2, 2014 | 01:51 AM
Rocketowner's Avatar
Welcome to CO.Someone may have some parts available if you make a list of what's needed in classified parts needed ,or scan parts for sale list. Good luck, Larry
Old Apr 2, 2014 | 08:17 AM
Oldsguy's Avatar
Past Administrator
They just don't make garages as long as they used too do they?
Old Apr 2, 2014 | 08:45 AM
Welcome, I like the before and after pics of the engine, looks good.
Old Apr 2, 2014 | 08:49 AM
citcapp's Avatar
Welcome form the left coast
have fun with the build nice looking Olds
Old Apr 2, 2014 | 09:04 AM
jsz66stang's Avatar
Smile newbee
I sold my 66 mustangs and am looking for a cutlass that I can restore a 70 is prefored but i'll take a 67 442
Old Apr 2, 2014 | 10:04 AM
Welcome.
Old Apr 2, 2014 | 03:37 PM
88jetstar's Avatar
Thanks, yeah i have to reorganize my garage so i can park it
fiona72
Aug 31, 2013 11:32 AM
kruss77
Aug 21, 2009 07:35 AM
Steeb
Feb 18, 2009 02:01 PM
Brizio
Feb 15, 2009 07:07 PM
southcarolina803
Jun 28, 2008 07:33 PM
